R57 Trunk molding/trim...
Old Sep 3, 2015 | 12:10 PM
BucksCountyR57's Avatar
BucksCountyR57
I know I have seen posts on here before regarding the molding/weather stripping where it transitions form the the fabric (of the convertible) to the trunk. Example photo:
Is there a thread or sticky that shows how to remove and install this? Maybe I suck at searching but I can't seem to find that. I am guessing this is pretty straight forward and will pull/pry off...but any tips or advice on how to approach it as to not hurt or damage any of the hardware holding it on would be greatly appreciated.
Recent 1st time owner of a 2011 R57 S.
Thanks !!
Old Sep 7, 2015 | 07:13 AM
2011cooperSconvertible's Avatar
Thanks !!
I'm also a recent 1st time owner of a 2011 Cooper S convertible. The same molding around mine was badly cracked as well. My mini dealership charged $350 including the new trim piece to replace. I know that doesn't answer your question, but in case you wanted to avoid the hassle of doing it yourself, that's what you're looking at. I was pretty happy with the results.
Happy motoring!
Old Sep 7, 2015 | 08:12 AM
Thanks !!
I'm also a recent 1st time buyer of a 2011 Cooper S convertible. I love it! The back molding was also badly cracked on mine. My local Mini dealer replaced it for $350 including parts. I know that doesn't answer your question, but just in case you decide it's not worth the hassle of doing it yourself, there you go.
Happy motoring!
Old Sep 10, 2015 | 12:30 PM
Hello,
Very similar to the R52 Convertible removal. You have a couple screws and the center rear top brake light. You open the trunk up, put the convertible top and trunk loading mode and it exposes the trim and screws , then work them off and install new.
Diagram
http://www.realoem.com/bmw/enUS/show...06#54347375319
R57 Parts 54347375319 KT
http://www.ecstuning.com/Search/SiteSearch/54347375319KT/
Here is the install kit , which is mostly new screws all around. The little pieces are adjustment for the alignment on the mounts facing forward closes to the rear side windows. Just mark and not where the old ones are.
54342758526 Mounting Trim Kit
http://www.ecstuning.com/Search/SiteSearch/54342758526/
Old Sep 12, 2015 | 03:12 PM
texaswadefish's Avatar
texaswadefish
On my 2011 R57s the rubber molding on this trim piece has failed on both side in the front. Does anyone know if I can replace just the rubber or do I need to replace this entire trim piece?
Old Sep 14, 2015 | 07:16 AM
Its the whole trim/ those two pieces. The hardware is linked about if you need them,. The screw heads can rust or strip out if the convertible is a year round driver. Otherwise you should be ok.
Old Sep 20, 2015 | 03:35 PM
BucksCountyR57
thanks!!!
Thanks everyone. my original hardware was fine so I ordered the replacement kit and it went on easily
Old Sep 21, 2015 | 05:42 AM
You are welcome, glad I could help.
muddpa
R57 :: Cabrio Talk (2009+)
Jan 3, 2024 11:44 AM
Damion J Constantopoulos
Feb 15, 2017 06:03 AM
w35773
Apr 19, 2016 12:35 PM
