R56 The pinch bolt missing on coils
Old Aug 25, 2015 | 06:10 PM
minibenworks's Avatar
minibenworks
I installed springs on my 07' MCS and I look under my Mini 2 months later to find my pinch bolt missing. The bolt I am talking about is the one that connects to the shock. It is gone on both front wheels. Are these important to have? Because i push the car and it feels normal..
Old Aug 26, 2015 | 10:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, buy a new bolt and nut for both sides. The piece that is above in the middle picture should be lined up with where the bolt inserts, I believe. Hex Bolt 07119905408 and Nut 33306777695.
888.280.7799 | 6am - 5pm PST
Old Aug 27, 2015 | 06:21 AM
richardsperry's Avatar
richardsperry
Seriously? Both sides are missing? lol
Just replace them. That ear must go in the slot before you put the bolt in. It's there to prevent the strut from coming out of the front hub... (like it is in the pictures)
Old Aug 27, 2015 | 06:42 AM
Ryephile's Avatar
Ryephile
That's absolutely not safe to drive. The strut isn't being held into the knuckle. Fix it correctly and use a torque wrench this time.
Old Aug 27, 2015 | 06:47 AM
w4r3z's Avatar
w4r3z
Be careful you strut is coming out. Maybe put some blue locktite.
Old Aug 27, 2015 | 06:51 AM
Ryephile's Avatar
Ryephile
Loctite isn't necessary for that fastener, just correct torque on the nut/bolt.
Old Aug 27, 2015 | 12:24 PM
Bea5tMa5ter's Avatar
Bea5tMa5ter
Holy shmoley! That looks dangerous to drive!
Old Aug 27, 2015 | 12:46 PM
TBRoye's Avatar
TBRoye
Just looked again at the pictures after looking a diagram. Park that sucker until you fixe it. That is way to dangerous to be driving. Hat a bump wrong and scratch on Mini and or Driver/passenger. If you had your car inspected by a state that requires it, you wouldn't be driving it home.
Tom
Old Aug 30, 2015 | 10:45 AM
minibenworks
Does anybody know the torque specs for the bolt?
Old Aug 30, 2015 | 08:14 PM
cristo's Avatar
cristo
Alliance Member
100 Nm, 74 ft-lb.
Old Aug 30, 2015 | 08:45 PM
minibenworks
Originally Posted by cristo
100 Nm, 74 ft-lb.
Thanks, will be sure to torque it.
rob76turbo
Sep 15, 2015 10:11 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 3, 2015 10:29 AM
