R56 Oil leak
Old Aug 25, 2015 | 03:06 PM
hooverr77's Avatar
hooverr77
Oil leak
Getting the oil changed today the shop showed me oil on the upper passenger side of the car. Anyone know where I should start looking? Thank you for the help!!
Old Aug 26, 2015 | 10:58 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
It could be the chain tensioner as it has been known to not have been properly torqued at the factory. Some good info as well at post #17 in this NAM thread here.
888.280.7799 | 6am - 5pm PST
Old Aug 26, 2015 | 11:45 AM
Kimolaoha's Avatar
Kimolaoha
Thanks.
Read the thread and infer, but will nevertheless ask, the following:
Is this an N14 issue only, or does it also apply to the N18s?
Old Aug 26, 2015 | 01:05 PM
PelicanParts.com
Vendor
Originally Posted by Kimolaoha
Thanks.
To the OP, if not the tensioner, could be the crankshaft seal or valve cover.
As far as chain rattle, people say the N18 does not have the same timing chain issues. However, time will tell. As the engines have the same oil consumption issues, that lead to guide wear. We will have a timing chain tech article releasing soon with a lot of information in regards to the timing chain issues.
Old Aug 26, 2015 | 02:10 PM
Kimolaoha's Avatar
Kimolaoha
Thanks - I'll definitely be interested in your article.
Old Aug 26, 2015 | 02:16 PM
PelicanParts.com
Vendor
My pleasure. I'll be sure to update with a link once the article goes live.
Old Aug 27, 2015 | 05:16 PM
Slave to Felines's Avatar
Slave to Felines
From what I have read around here no 2nd-gen MINI is immune to the chain tension problems. The earlier S models (and possibly JCW) seem to be the most prone to them, but even the later N18 cars can occasionally have them show up as well. We've even read one or two cases of a non-S car having the same sort of trouble.
Old Aug 27, 2015 | 05:21 PM
hooverr77's Avatar
hooverr77
Can this be tightened by myself or do I need to take it in? And thank you for all the help!
Old Aug 28, 2015 | 07:17 AM
PelicanParts.com
Vendor
Yes, you should be able to. I'd link the thread, but this site is blocked from being posted here.
The head of the tensioner is the large hex head in the center of the picture (rear top of the engine on the passenger side)...
The timing chain tensioner to cylinder head tightening torque is 48 ft-lb
Old Aug 28, 2015 | 07:39 AM
Kimolaoha's Avatar
Kimolaoha
Isn't the tensioner bolt pictured twice in the NAM thread referenced up in the second post?,
i.e. here:
https://www.northamericanmotoring.co...ml#post3211726
and here:
https://www.northamericanmotoring.co...ml#post3243999
And I think I recall reading that the tensioner's head was 27mm, just like the oil reservoir cap - no?
Old Aug 28, 2015 | 07:55 AM
PelicanParts.com
Vendor
i.e. here:
and here:
And I think I recall reading that the tensioner's head was 22mm, just like the oil reservoir cap - no?
Yes, that thread has a lot of great info that is needed for the tensioner. Post #48 here also includes an image of the torque spec. Post #71 here has torque spec as well and says 27mm in size.
Old Aug 28, 2015 | 08:09 AM
Kimolaoha's Avatar
Kimolaoha
Yep, I meant "27mm - just like the oil filter cap". Corrected above now.
Thanks.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
