Recently bought an R56 with 53k miles. Need some help...
Old Aug 24, 2015 | 06:43 PM
MasterShaftner's Avatar
MasterShaftner
Alright. So recently I got a 2007 mini s and it's been running great.
But about a week ago a half full check engine light came on.
So I just bought a diagnostics scanner to see what I could find.
28aa bypass blow off valve, plausibility
2b64 intake manifold, unmetered air
2DCA fuel shut off due to super knocking, cyl. 4
2D52 super knocking******
This is what I found! Can anyone tell me how to fix these maybe? In note my mpg has gone from 23.4 to 23.2...
Any help would be great.
Old Aug 24, 2015 | 07:19 PM
Systemlord's Avatar
Systemlord
Whoever you bought the Mini from probably install a BOV which vents to atmosphere which is causing some or all of your problems. First our Mini's are supposed to have a recirculation valve that do not vent to atmosphere resulting in unmetered air, a recirculation valve does exactly that, it recirculates the air back into the intake tract instead of venting it to atmosphere.
Your ECU measures the air mass and temperature at the MAF sensor located right after the air filter and is detecting some of that air mass escaping from the intake system though the BOV. This air mass and temperature of the air is used by the ECU to calculate the proper air fuel ratios, now your air fuel ratios are off from what they should be.
Please take a picture of you BOV located on your turbo housing.
Old Aug 24, 2015 | 07:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That combo of faults can be caused by several things. The first thing I would do is a smoke test to check for vacuum leaks. Then check the diverter valve and go from there.
Old Aug 25, 2015 | 05:15 PM
MasterShaftner
The site won't allow me to post the picture but it looks all stock on the turbo
Old Aug 26, 2015 | 01:10 AM
MasterShaftner
My scanner is saying its misfiring in two cylinders, could that be it?
Old Aug 26, 2015 | 10:03 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
2B64 I believe is Downstream Throttle Air Leak - P1497 here and here. Have you done a pressure test like advised above? Start there.
888.280.7799 | 6am - 5pm PST
Old Aug 26, 2015 | 12:54 PM
sub3622's Avatar
sub3622
I had 2b64,2dca and 2d52 a while back.
2b64 i had it when i installed K&N open filter (typhoon) and disappeared once i changed to box air intake.
2dca and 2d52 disappeared once i replaced the HPFP on my r56 S 08'
Old Aug 26, 2015 | 05:57 PM
mbwicz's Avatar
mbwicz
I would follow the advice above, and then check what maintenance has been done on the car. It is likely that you have some significant carbon buildup in the intake ports and the valves. This can contribute to misfires and can be cleaned up with walnut blasting. A set of plugs would not hurt, either.
Even though your car doesn't have lots of miles, there is some need for maintenance. Do you have a history of what has been repaired/fixed/maintained on the car?
Mike
Old Aug 27, 2015 | 09:57 AM
Grizld700's Avatar
Grizld700
Originally Posted by mbwicz
it is likely that you have some significant carbon buildup in the intake ports and the valves. This can contribute to misfires and can be cleaned up with walnut blasting. A set of plugs would not hurt, either.
+1000000000
Old Aug 27, 2015 | 01:47 PM
tylewis's Avatar
tylewis
I got mine at 49 and around 51,000 I got a check engine. I had some similar codes when I took it to my speed shop. It ended up being a thermostat housing. I am not saying thats what yours is, but to repeat what he said, often times these codes piggyback off of each other and can cause unusual readings. I agree with the smoke test and what not. My guy told me to get the bigger of the codes resolved and see if the other codes go away, thats what happened to me. So my experience would say resolve the biggest issue, see if the other ones go away.
Old Aug 28, 2017 | 04:35 AM
Jwp2's Avatar
Jwp2
Hey Folks,
I have a similar problem. I have the yellow half engine light. I have 3 of the same 4 faults:
28AA Bypass blowoff valve Plausibility
2D52 Engine ECU super knocking
2DCC fuel shut off due to super knocking, cyl. 1
its a 2011 jcw with 48k miles.
I bought the Schwaben tool and monitored the fuel pressure in relation to the throttle position....seemed to track but I have no idea of the values that I should see.
Interestingly, prior to this the car would give a little pop (backfire) when I abruptly release the throttle but no negative effects. Another interesting artifact...the yellow half engine light goes out....and stays out unless I get the car over say 3K rpms. Leads me to believe the diverter valve, but I can't be sure.
I also checked all around the engine and turbo and didn't see any loose connectors or vacuum lines. I just ordered the diverter valve from ECS (cheaper than pelican with added shipping). I also plan to do the walnut blasting next weekend.
Any other ideas?...Has anyone else experienced this combination of faults.
Thanks in advance!
Old Aug 28, 2017 | 04:58 AM
mbwicz's Avatar
mbwicz
Its old enough that there could be some significant carbon build up on the valves and in the intake ports. It also is likely on the original plugs. The carbon may be contributing to the super knock code.
Just a thought. Its not difficult to pull the intake and look down the ports with a light and mirror to see how the carbon looks.
Mike
Old Aug 28, 2017 | 06:43 AM
Jwp2's Avatar
Jwp2
Mike
yeah. Plan to pull it off and clean the valves this weekend.
Thanks!
Old Aug 28, 2017 | 02:31 PM
mbwicz's Avatar
mbwicz
FYI, you need special equipment to clean the valves, not just a can of solvent and a pick. The carbon is really stuck in place. The dealer uses a walnut shell blasting method. You want to try and avoid getting crap into the cylinder. There are how-to instructions on this site.
Mike
Old Aug 28, 2017 | 04:03 PM
Jwp2's Avatar
Jwp2
Thanks for the info Mike!
Yes, I've read the posts and have most of the equipment in my garage already...walnut shells arrived on Friday. ;>}
I'll post results when finished. Really hope this clears the issue and codes.
Old Aug 28, 2017 | 05:34 PM
seandallen's Avatar
seandallen
I did the walnut blast. I bought the media blaster at Harbor Freight for $90 on sale. The vacuum hose adapter is about $90, too. If you have a shop-vac and an air compressor (you need a lot of air), that should be all you need. Pelican has the best step-by step walk-through in my opinion.
Don't forget to clear ALL your codes before you restart it. PM me if you run into problems.
Old Aug 29, 2017 | 07:55 AM
PelicanParts.com
Vendor
Or, you can use this method, which requires you to purchase nothing: http://www.pelicanparts.com/techarti...n_Cleaning.htm. Still a good method and will give you the same results.
Old Sep 1, 2017 | 07:23 PM
Jwp2's Avatar
Jwp2
Thanks for all your help folks...
I replaced the diverter valve and she is running great now...no more codes.
I will do the valve cleaning tomorrow to complete the project.
maestro39
Oct 27, 2015 02:38 PM
PrimePower
Aug 16, 2015 06:29 PM
Fizzyx
Aug 14, 2015 08:24 PM
cjsdad
Aug 11, 2015 08:46 AM
marendt428
Aug 8, 2015 04:44 AM
