Renowned: The Morimoto Elite Systems have earned their reputation amongst many as the aftermarket's best set of HID's.
HID Ballasts: The all new XB ballasts feature relocated igniters like OEM units, putting them far closer to the HID bulb. The lack of high voltage transmitted through wiring drastically reduces EMI/RFI (radio interference). Total system reliability is also improved by shielding the main circuit board from the static produced by these high voltage bursts on start up.
HID Bulbs: At the heart of the XB H8 bulbs is their perfectly aligned 100% Philips Quartz glass that houses a capsule from APL-USA. Using high quality halide salts from German-supplier Messer; the bulbs produce nearly the same luminosity (intensity) as the amazing Osram CBI bulbs at 5500K.
Canbus Compatible: The Standalone Canbus harness substitute is recommended for European vehicles that display "bulb out" error messsages. They contain a series of capacitors and resistors to trick the car into thinking nothing has changed and help you avoid annoying lamp-out warnings on the dash.
Additionally, we here at AZN Optics can outfit your vehicle with matching LEDs to complete the modernization look! Just PM with any questions!
