JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Just installed NM Engineering air charge tubin and CAI
Old Aug 10, 2015 | 10:17 PM
minimofo's Avatar
minimofo
Just installed NM Engineering air charge tubing and CAI
Received my goodies from the great Jerry at NME today. Easy install of 2 things tonight while waiting for the ECU stage 1 flash to come back on Wednesday.
These will be installed on Thursday along with ECS' Exact-Fit red stainless steel brake lines and Motul RBF600 brake fluid.
ECU out and on its way to NME for stage 1 flash.
Old Aug 11, 2015 | 04:18 AM
Drivehard's Avatar
Drivehard
Nice. You went all in.
Tells us how that short shifter feels when u get the DME back.
Nice garage. Epoxy floor with sprinkles. Good lighting. And if what's in your sig is true ..... Well there u have it. Lol.
Sent from my iPad using NAMotoring
Old Aug 11, 2015 | 05:01 AM
Well done and nice list, post up a pic of the ECS brake lines when installed.
Old Aug 11, 2015 | 02:56 PM
minimofo's Avatar
minimofo
will do. i'll install the short shifter when i do the oem gp rear diffuser since the exhaust needs to come off to get to the lower shifter link.
thanks, yes it's true
minimofo's Avatar
minimofo
will do. i'll document with a few pix.
Old Aug 12, 2015 | 05:33 AM
Great thanks
" gp rear diffuser "
This is a great upgrade to the rear JCW bumper.
Old Aug 12, 2015 | 09:48 AM
Grizld700's Avatar
Grizld700
I'm assuming you did, but I feel obligated to ask anyway.....
You did remove the plastic off that air filter didn't you?
Old Aug 12, 2015 | 01:33 PM
minimofo's Avatar
minimofo
yes i did remove it ;-) left it on until the ecu comes back.
Old Aug 12, 2015 | 01:44 PM
minimofo's Avatar
minimofo
nm engineering engine mods completed
just got the ecu today (shipped out to them on monday, received back on wednesday). took me 2 mins to reinstall and put the cover back on. wow!!! it's what i can say with the transformation of the performance. the jcw now pulls so strongly. i'm losing traction in 1st and 2nd gear and into 3rd when power shifting. the power band is much wider, and torque comes in sooner. see nme's site under engine-ecu-dyno for the specs (http://www.nm-eng.com/media/attachments/269_r56dyno.pdf). the combination of air charge pipe, discharge pipe, cai, and ecu stage 1 flash all made up for a significant gain in performance.
what you get with nme stage 1 software - remaps boost pressure, ignition timing, air fuel ratio, throttle response and rev limiter for manual tranny.
even better is the swooshes from the factory bov ;-) the swooshes are as the result of the open airbox and higher boost. also, the upgraded piping eliminated the stock pipe's muffler (for sound deadening purposes) and voila. it's not an annoying and loud swoosh like aftermarket bov's but definitely noticeable inside/outside the car and very respectable. combined with the suction sounds from the cai (not crazy loud at all), my jcw is now so much fun. the exhaust (removed resonator and 2ndary cat before) now backfires even more and pops louder. i will check tonight to see if i can get some sparks
i've taken it out for a 30 mins test drive. from the time i fired it back up with the flashed ecu until i got home - no CEL and no MIL whatsoever. the car is driving just fine thus far, and all the mods just simply work!
kudos to the folks at nme for their high quality products, excellent fitment, clear and easy instructions...but most of all for their great customer service. jerry at nme has been very helpful in answering all my silly questions quickly and in guiding my decisions...great job!
here's a finished engine project that took me 2 nights (while waiting for ecu to come back) and a quick clip of the bov's swooshes...enjoy!
Old Aug 13, 2015 | 05:37 AM
minimofo's Avatar
minimofo
Great thanks
Absolutely! The GP diffuser is in the plan and very soon...
Old Aug 13, 2015 | 05:47 AM
teinesina's Avatar
teinesina
I'm so glad you just posted this! I was in my garage last night putting the intake and charge pipe too!
Only I gave up on the charge pipe (cold-side) because I couldn't get the old one off. I could not get the lower end to release. It was so tight in there I just couldn't get the right leverage and angle to pull it off. Or is there a trick to it?
At least I got the intake on and now the charge pipe is easy to access!
How did you get yours off?
Old Aug 13, 2015 | 05:57 AM
Awesome !
Old Aug 13, 2015 | 07:22 AM
minimofo's Avatar
minimofo
i used a long flat blade screwdriver to pry off the oem pipe. takes a lot of work but how i did it.
Old Aug 13, 2015 | 04:54 PM
minimofo's Avatar
minimofo
Here are the pix. I started a new brake upgrade thread: https://www.northamericanmotoring.com/forums/jcw-garage/291934-slotted-rotors-hps-pads-exact-fit-ss-lines-and-motul-done.html#post4113124
The Exact-Fit brake lines fit perfectly, thanks!
Old Aug 14, 2015 | 05:24 AM
Here are the pix. I started a new brake upgrade thread: https://www.northamericanmotoring.co...otul-done.html
Awesome, looks great and thanks
Old Aug 21, 2015 | 01:46 AM
malibujoey's Avatar
malibujoey
ever forget the JCW is down there when you lower the Lamborghini?
haha 2 sports car extremes. extreme cheap. extreme expensive. thanks for telling us where NM is. up the freeway from me in Malibu. drive over there and see if they install.
Old Aug 21, 2015 | 02:44 PM
minimofo's Avatar
minimofo
LOL never! The lift has a master power switch so even if I forget and just push the lever to lower it - just won't happen ;-)
I'm loving all my mods so far from NM Engineering, especially the stage 1 ECU map...lots of torque down low for big smiles and that swoosh coming to life is a lot of fun. Over 500 miles with the NME mods and NO CEL or MIL of any kind. It just all works ;-)
Old Aug 22, 2015 | 02:34 AM
malibujoey's Avatar
malibujoey
haha You're an interesting dude. First - nice engine shots of your turbo upgrade and documenting your engine work. Inspiring me to go for it.
But curious: why are you pissing around putting in 100 dollar upgrades to a cheap sports car like the JCW when you got a monster 6 figure racing machine hanging over it's roof???
Don't get me wrong - I love my JCW. But it was only 36 grand new. I would take a 911 turbo if I had the choice.
Old Aug 23, 2015 | 12:39 AM
minimofo's Avatar
minimofo
I love cars and doing easy mods to get the biggest smiles per $. The JCW is simple to work with. Doesn't matter the price of the car to me. I love my JCW, since it's my daily driver I can zip around in. If I break something in my mods, it's cheap to replace. My JCW loaded with dealer installed CF wing and gauges was $37K but bought brand new at end of model year for only $33K.
I already installed the QuickSilver Titan titanium exhaust on the Lambo so the V10 can scream bloody murder as it should be. There's not much else to do on an otherwise perfect car for me already.
I've tallied all my JCW mods so far including NME wheels and tires...$6887 incl. all taxes, shipping, install/services I don't do myself (realignment, tire mounting, brakes). That's a little over just the Lambo's exhaust incl. installation alone
Old Aug 24, 2015 | 06:59 AM
Its great you love the JCW so much and have so much fun, I love my JCW and have driven many other cars and I really like mine.
Old Aug 25, 2015 | 10:35 PM
minimofo's Avatar
minimofo
Check out my latest 3 posts/mods. The car is even more fun now ;-) I can't wait for delivery of the Orranje GP wing that's due to arrive mid-September. That will complete my JCW project for a while. I may consider doing the Sprint Booster throttle mod and bigger intercooler (with NME stage 2 flash) later...
Old Aug 26, 2015 | 04:55 AM
Awesome. Post up some pics when your done.
Old Aug 26, 2015 | 08:55 AM
cmacattack's Avatar
cmacattack
Great thread, thanks for posting all of this!
Old Aug 27, 2015 | 03:09 PM
malibujoey's Avatar
malibujoey
Very inspiring MiniMofo. You sound like a true car guy. Yeah I'd probably try out a lot sports cars and come back to the JCW.
Damn I should have gone with a year end newer model. hahaha Didn't know much about them at the time a year ago. I got a sweet '11 JCW with really low miles and a 100K warranty. Also nice install photos. Show us more when you get a chance.
Old Aug 27, 2015 | 04:29 PM
minimofo's Avatar
minimofo
Well any car can be improved, customized, personalized, etc....all personal taste as long as it's tasteful and functional. I like doing it as much myself as possible to learn and get the gratification that I've achieved something more so than just saving $ given to someone to do it for you.
