Interior/Exterior Chrome Toggle Blanks
Old Aug 3, 2015 | 08:33 PM
mct's Avatar
mct
Does anyone know where you can buy chrome toggle switches to fill in the blank spaces on the F56 if you didn't option the car with the parking assist feature? Would like to fill out the toggle bank if possible...
Old Oct 26, 2015 | 07:06 PM
GregoryK's Avatar
GregoryK
You cannot buy individual switches. Check Realoem fit your car.
Old May 1, 2016 | 03:58 AM
ULTIMATEMINI's Avatar
ULTIMATEMINI
The fully equipped toggle bank is easy enough to buy. I would also like to install the fully equipped little bank but I'm not sure how to take out the present bank and how to install the new one. Does any one know how to remove the toggle bank and does anyone know if the car control system will recognize that the "wrong" type of toggle bank is installed give an error?
Old Nov 29, 2017 | 08:01 AM
phantasms's Avatar
phantasms
Any update on this?
The car I'm getting is missing the switches on the end. I'd like to get a new bank full of switches so I can use the ones on the ends for oil slick and smoke screen.
Thanks!
Best,
Gene
hmmm....Looking at the back of this thing I'm not very hopeful on a retrofit. I was hoping for standard switches that I could run whatever wires to it I wanted.
Anyone ever crack one of these open?
Old Nov 30, 2017 | 08:24 AM
CooperT's Avatar
CooperT
Here's the link to this on ECSTuning: https://www.ecstuning.com/b-genuine-...e/61319328290/
I'm guessing these toggles are soldered to a PCB directly. To access the switch would require programming to interface the CANBUS.
Found this online on reverse engineering the MINI CANBUS: http://bobodyne.com/web-docs/robots/...N/MINI_CAN.pdf
Now if you opened up the switch bank, you may be able to isolate a switch, or tie in to it. But may need diodes to prevent feedback into the CANBUS and damaging the computer. Again, this is all my opinion. YMMV.
Last edited by CooperT; Nov 30, 2017 at 08:27 AM. Reason: More thoughts on this...
Old Nov 30, 2017 | 08:30 AM
phantasms's Avatar
phantasms
Hmm... doesn't seem worth the effort. I saw there's one on eBay. I may get it and rip it open and see if I can install some simple toggle switches and run the wires out the back.
Thank you!
Old Nov 30, 2017 | 09:10 AM
CooperT's Avatar
CooperT
You may be able to isolate the existing toggles. But it may require a good bit of hacking. The ones are eBay are only $100, so hacking in to that seems less nausea inducing than hacking in to ECS's for $200+.
Old Nov 30, 2017 | 07:18 PM
TVPostSound's Avatar
TVPostSound
Correct, they’re only Canbus switches.
You might get get an error, as there will be nothing
to activate.
Old Dec 20, 2017 | 09:01 AM
Yes, they are programmed to the car. You would have to add those options then have the dealer flash it to work based on what I have seen. Unlike the Gen 2 MINIs where you could add the toggle and then flash to work. Most of the new stuff is built in. You could install it and then put sticker on it like the gen 1 MINIs.
https://www.northamericanmotoring.co...ch-decals.html
Old Jun 30, 2019 | 12:22 PM
J_L's Avatar
J_L
Bumping this old thread- did anyone try hacking into the switches on this panel?
I'd like to get a panel that includes the leftmost switch, and turn that into an exhaust cutout switch. Concerns though-
-how hard is it to get that panel out? I found these instructions:
https://www.newtis.info/tisv2/a/en/f...sor/1VnY04pWlC
Do I really need to pull out the stereo unit? I'm assuming I could leave it plugged in to avoid possible need for dealer reprogramming they say would be needed for my pre-11/2014 car.
-but will the car need programming, just because it's a different switch? Or just the park distance feature wouldn't work- which of course it wouldn't, I'm not hooking up the rest of those parts.
-I realize this is a canbus switch, so I'm not going to be able to just wire into it. But if I can physically chop into the parts, and get another switch to fit in behind that's activated by this one, that'd do. If I start cutting up that part of the board though, will I brick the whole thing?
Probably nobody knows this last one, but I'm willing to give it a try if anyone has advice on the other items.
Thanks for any help!
Old Dec 23, 2020 | 04:23 PM
6FT6's Avatar
6FT6
You dont need to remove the headunit, just the screen (if its the 6.5 or 8.8). If its the standard radio then I guess its all-in-one and you will have to remove the whole thing.
I was bothered by the missing toggle myself, but the hassle outweighed my OCD.
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
got_mini?
Oct 7, 2015 02:12 PM
whowantstorace
Sep 27, 2015 06:16 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
