R56 Lower Radiator Hose question
Old Jul 29, 2015 | 01:28 PM
venturaexit's Avatar
venturaexit
Is this the lower radiator hose connecting to the Thermostat Housing? This is right behind the front splitter. (looks confusing because I used a mirror to take the picture.) car is a hatch R56 w JCW front bumper.
Old Jul 29, 2015 | 01:35 PM
Yes, Its the lower hose and it has a leak at the clamp or the hose is split. 17122754223
http://www.ecstuning.com/Search/SiteSearch/17122754223/
There is little clamps that hold it into the lower core support so it will not hang down.
https://www.northamericanmotoring.co...-cooper-s.html
Old Jul 29, 2015 | 02:30 PM
venturaexit
Originally Posted by ecstuning
yes, its the lower hose and it has a leak at the clamp or the hose is split. 17122754223
http://www.ecstuning.com/search/sitesearch/17122754223/
there is little clamps that hold it into the lower core support so it will not hang down.
thank you!!!
Old Jul 29, 2015 | 02:36 PM
Originally Posted by venturaexit
thank you!!!
You are welcome.
Old Jul 30, 2015 | 11:25 AM
venturaexit
and by the way, what is this?
Old Jul 30, 2015 | 12:04 PM
Corrosion on the turbo or coolant residue , looks like the stop plug /gasket for the turbo is leaking coolant just barley . Its so the turbo can be used with other car engines There is not part number for that part from MINI , but on the front side is the coolant lines. Wipe it off and see if it comes back or you can see dips. Car turbo looks pretty new, are under warranty ?
The washer from the front might work.
http://www.realoem.com/bmw/enUS/show...diagId=11_3946
http://www.ecstuning.com/Search/SiteSearch/07119963201/
Also you can have the dealership or yourself replace the height shield with updated version.
https://www.northamericanmotoring.co...-recall-3.html
Old Jul 30, 2015 | 12:13 PM
venturaexit
Thank you so much, another part goes in the cart!
Old Jul 30, 2015 | 12:22 PM
venturaexit
One more photos!
I noticed few areas where there might have been something and may be missing... bought the car used few months ago
If you would be so kind to tell me what was in the 3 circled areas if anything...
Old Jul 30, 2015 | 12:43 PM
#1 comes with clips. Looks like they lost it.
http://www.realoem.com/bmw/enUS/show...diagId=13_1212
There is no part number for that clip, this is the closest I could find. 51642755036
http://www.ecstuning.com/Search/SiteSearch/51642755036/
#2 hold the wire harness for later models who had the harness. I don't see any wire harness , unless they slid it under the intake and around the corner.
Before they added the additional harness, but has the clip.
#3 for the factory alarm sensor. Two piece in the bottom left corner of our pics
R56 9/2009+ , which then have to be installed and then flashed by MINI dealership.
http://www.ecstuning.com/Search/SiteSearch/65120443179/
Old Jul 30, 2015 | 12:55 PM
venturaexit
Old Aug 31, 2015 | 02:39 PM
venturaexit
[QUOTE=ECSTuning;4108199]Corrosion on the turbo or coolant residue , looks like the stop plug /gasket for the turbo is leaking coolant just barley . Its so the turbo can be used with other car engines There is not part number for that part from MINI , but on the front side is the coolant lines. Wipe it off and see if it comes back or you can see dips. Car turbo looks pretty new, are under warranty ?
UPDATE: (turbo - coolant residue) So far after one month that I cleaned these leaks residues off, it's still clean, I will keep an eye on it.
Thanks!
Old Aug 31, 2015 | 02:43 PM
venturaexit
UPDATE, BOTTOM COOLANT HOSE: It leaks a bit, almost nothing, but I'm replacing it next week, just got the part from ECS (cheapest around)
My mechanic tells me that the clams holding the hose up are fine and all its fastened properly, but still IT HANGS 1/4 lower than the bumper. Don't they make a shield for this hose, maybe something I can bolt on so when I scrape the bumper I don't scrape the hose?
Thanks!
Old Aug 31, 2015 | 02:52 PM
Thanks for the order.
With a new clamp , it hangs a hair , but not too much. Check the clip in part also on the clamp.
https://www.northamericanmotoring.co...-rad-hose.html
Some people get the belly pan for extra hold up insurance.
Old Aug 31, 2015 | 03:04 PM
venturaexit
Thank you so much!
jkapinos's Avatar
jkapinos
Yes the GP belly pan does a good job. It's yet jUst one more reason to get one.
Old Aug 31, 2015 | 03:09 PM
venturaexit
Old Aug 31, 2015 | 05:38 PM
Tio Barry's Avatar
Tio Barry
I use zip ties to keep it up. The radiator hose that is.
Old Sep 1, 2015 | 04:52 AM
Thank you so much!
You are welcome.
silence2-38554
Nov 12, 2015 09:39 AM
tr3y003
Oct 22, 2015 10:48 AM
G1HQ
Aug 28, 2015 01:41 PM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
