View Poll Results: Your interest in potential brake upgrade types
Stock rotors (I don't plan to or have any interest in upgrading)
15.52%
Larger plain rotors
11.79%
Drilled rotors
4.72%
Slotted rotors
36.35%
Wave rotors
2.16%
Drilled and slotted rotors
29.47%
Voters: 1018. You may not vote on this poll
Brake upgrade survey
Old Aug 4, 2004 | 07:54 PM
Mark's Avatar
Mark
North American Motoring :: Founder
Everyone,
Lately I've received a lot of interest from vendors in figuring out what type of brake kits people are interested in upgrading to. If you could take a second and cast your vote in the above survey I would greatly appreciate it. Here is some information on each of the following types of brakes:
  1. Stock rotors (I don't plan to or have no desire to upgrade)
  2. Larger solid rotors
  3. Drilled rotors
  4. Slotted rotors
  5. Wave rotors (Wave shaped edge which supposedly improves cooling and gives more leading edges for the brake pads to grip. To date only seen in some European magazines)
  6. Dilled and slotted rotors
Thanks for your input!
Mark
Old Aug 4, 2004 | 08:54 PM
discodan's Avatar
discodan
how come it says i cannot vote on this poll?
Old Aug 4, 2004 | 09:04 PM
kurvhugr's Avatar
kurvhugr
ditto
Old Aug 4, 2004 | 09:15 PM
discodan's Avatar
discodan
there we go.:smile:
Old Aug 4, 2004 | 09:17 PM
bferguson
Guest
Posts: n/a
Give it another try. I had to adjust permissions on the poll so that everyone can respond. Thanks!
Mark
Old Aug 5, 2004 | 05:52 AM
polmear's Avatar
polmear
by 'solid' rotors, you are only talking about the plates, I presume? not talking about unvented, solid rotors like the rears?
thx
Old Aug 5, 2004 | 06:56 AM
toddtce's Avatar
toddtce
I'll go on record as saying he means 'plain' rotors, not really 'solid' ones. Man, those suckers would weigh a ton..!
Old Aug 5, 2004 | 07:12 AM
Mark's Avatar
Mark
Yes...I meant larger plain rotors. I've updated the survey to reflect this. Thanks!
Mark
Old Aug 5, 2004 | 07:38 AM
MGCMAN's Avatar
MGCMAN
Interested primarily in slotted rotors. Improved performance, plus less subject to cracking than drilled or drilled and slotted rotors.
Old Aug 5, 2004 | 08:51 AM
hayaku's Avatar
hayaku
i assume this is for rotors only?
my vote would go for lighter, larger, curved vane directional, 3 slot, floating rotors... all performance, no bling... :smile:
if we're talking calipers too, then 4 piston front, 2 piston rear, monobloc, with same brake bias as stock, lightweight... alcons pretty please?
Old Aug 5, 2004 | 10:20 AM
polmear's Avatar
polmear
OOh, OOH put me down for a set o' deese! pleese! while you're at it make 'em cheap, too!
Old Aug 5, 2004 | 07:56 PM
Docofmind's Avatar
Docofmind
Why monobloc? 2 piece is actually stronger and more rigid. Brembo started using the 1 piece design because it was more cost effective.
Your request though, will be granted, except it wont be made by Alcon
Old Aug 6, 2004 | 05:08 PM
hayaku's Avatar
hayaku
simply for quick pad changes. i'm lazy and track prep is long enough... nevermind about having to swap pads at an enduro... hot brakes and all...
Old Aug 6, 2004 | 07:44 PM
toddtce's Avatar
toddtce
Then between the two of you, I pretty much have exactly what you want....
Non mono block, quick change pads, (hot or cold) directional rotors, lighter, gas slotted, non floating, correctly biased, no twin pot rears (not needed) and when you fit even the larger rear rotor you're still way under what you'd thought you'd spend!
I can't believe you slept through all those other posts...lol.....somehow we didn't hook up!
Old Aug 6, 2004 | 11:19 PM
Docofmind's Avatar
Docofmind
Why should it being two pieces extend the length of time needed for pad changes?
A simple bridge bolt across the top makes for easy pad changes. It also provides an even stiffer and more rigid chassis to minimize flex.
Click on this link for more detailed information.
http://http://wilwood.com/Products/C...4R14/index.asp
Old Aug 6, 2004 | 11:23 PM
Tüls's Avatar
Tüls
Turbius Maximus
where's the selection for BIG BRAKE KIT which also covers drilled and slotted...but big!!
Old Aug 9, 2004 | 10:15 AM
Monkey_Boy's Avatar
Monkey_Boy
I think Galfer has a patent on the wave design and is somewhat popular on motorcycles. Not sure how well received they'd be in a car, and how they'd work with ABS. There is a weird pulsation sort of feeling in the brakes with wave rotors. Also, I've seen no data showing they are any better than normal, round rotors (motorcycles).
Old Aug 9, 2004 | 10:20 AM
Pebblecrusher's Avatar
Pebblecrusher
Does this poll assume we can afford new brake kits?
Old Aug 11, 2004 | 02:40 PM
Mark's Avatar
Mark
In reviewing the responses I'm interested in knowing for those that selected slotted rotors what is your motivation? Is it relative to look, function, or both. Based on your answer can you provide a little background on why you feel the way you do? Thanks!
Mark
Old Aug 11, 2004 | 02:56 PM
pbraun's Avatar
pbraun
I have the Brembo GT brake kit in the front on my MINI and their rotors on the rear. They are slotted, not drilled. They do cost more than most kits, but I think the quality is tops! When those puppies warm up, just show me the dime and I'll stop on it. Time after time, all day long. No fade. I repeat - no fade - ever! Incredibly short stopping distance!
Brembos are the best ! so, there ya go! :smile:
Old Aug 25, 2004 | 04:09 PM
paddy's Avatar
paddy
Originally Posted by mferguson
Everyone,
  3. Drilled rotors
  4. Slotted rotors
Mark
Mark,
I voted for the slotted rotors, only because you left out slotted & dimpled. I would not put any type of drilled rotors on my MINI. I have replaced the fronts with EBC's slotted & dimpled.
pjo
Old Sep 2, 2004 | 02:48 PM
CTMINI's Avatar
CTMINI
Paddy,
Does that bronze sheen wear off the EBCs after you have stopped on them a few times?
I'm in the market for rotors like, real soon. Also - is it imperitive to replace your pads when you get new rotors if the pads are not old? (Think 3,500 miles.)
Old Sep 2, 2004 | 04:11 PM
paddy's Avatar
paddy
Originally Posted by CTMINI
Paddy,
The bronze sheen does wear off after they are bedded-in. I just looked at the rotors and both the EBC & OEM are the same color silver.
I have only replaced the front rotors and when I did, I also put new EBC Green Stuff pads on the front. On the rear, I replaced only the pads and then proceeded to bed-in the new parts. I did not replace the rear rotors as they only provide about 20% of the total braking force and for my application autocross & daily driver, it was not necessary.
If it was up to me, I would put new pads on with new rotors, that way everything is starting off from a known point. Just the way I look at it. When it comes times for new rotors, new pads will be installed at the same time.
paddy
Old Sep 2, 2004 | 07:05 PM
toddtce's Avatar
toddtce
All rotors treated with zinc or cad will only retain their plating where the pad does not rub it.
Old Sep 3, 2004 | 06:08 AM
polmear's Avatar
polmear
Paddy,
New rotors should always get new pads. The old pads, no matter how little they have worn, will take on the characteristics of the old rotors (i.e. tapered wear, grooving, coning, etc.) these 'bad' characteristics can be transferred to the new rotors, and trash your new rotors faster.
