R56 Oil drain plug washer
Old Jul 19, 2015 | 08:39 PM
tag1260's Avatar
tag1260
Recently bought a nice 2009 MCS and promptly took it out and hit a raccoon. Somehow the only damage was to the lower grill and I broke the axillary water pump. Literally broke one hose nipple off of the pump. Anyways, I am changing the oil while I'm into it and was wondering if a flat copper drain plug washer will work in place of the crush type? Nearest dealer is 75 miles away and I have a couple new filters that I got with the car so buying a new filter just to get the plug gasket doesn't make a lot of sense. Also can't justify driving to the dealer for such a small part. Does any other car use the same size crush washer?
Thanks.
Old Jul 20, 2015 | 04:21 AM
richardsperry's Avatar
richardsperry
New washer should be in the box with the new filter. (unless you just got a bunch of filters.)
But nothing unique about a drain plug washer. IIRC it's like 12mm? I've never really checked. Besides, You can probably get away with reusing it once.
Old Jul 20, 2015 | 04:52 AM
Capt_bj's Avatar
Capt_bj
Old Jul 20, 2015 | 05:06 AM
gjxj's Avatar
gjxj
not all filter makers give you the washer.
Old Jul 20, 2015 | 06:09 AM
tag1260's Avatar
tag1260
Is it an actual crush washer or the solid copper type? I have a Subaru aluminum crush and also a solid copper one here/ Will either work?
Old Jul 20, 2015 | 07:47 AM
ra2fanatic's Avatar
ra2fanatic
I use a Fumoto quick drain piece and have several washers. If you need a few pm me your address and I'll snail mail it to you. lol
Old Jul 20, 2015 | 09:58 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Can order a few here to keep them handy when it comes to doing oil changes.
888.280.7799 | 6am - 5pm PST
Old Jul 20, 2015 | 11:11 AM
We have them here, its a cooper crush washer, as posted above by capt_bj. On the Genuine MINI filter kit , it comes with one and on the aftermarket Mann and Mahle, its separate.
All discussed Here:
https://www.northamericanmotoring.co...il-filter.html
Old Aug 27, 2015 | 02:18 PM
mbwicz's Avatar
mbwicz
Make sure that you check to see your radiator support isn't broken. I ran over an animal, and it broke the lower bumper painted portion off (under the lower grille), and pushed the radiator support back into the aux water pump. The fan housing was also broken, that was what actually contacted the water pump. It turned into a decent amount of work to get it fixed.
Mike
Old Aug 27, 2015 | 02:20 PM
Bea5tMa5ter's Avatar
Bea5tMa5ter
How did the Raccoon make out?
Old Aug 27, 2015 | 02:26 PM
tag1260's Avatar
tag1260
Thanks but I didn't find any more damage than that. Can't for the life of me figure out what happened. I did find one paw stuck under the car and he had only one finger stuck out . I won't say which one but I don't think he was happy!!!
Capt_bj's Avatar
Capt_bj
who wants to see racoons making out?
wierd ......
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
ludedude
Aug 10, 2015 07:16 PM
