R56 2008 MCS engine woes
Old Jul 13, 2015 | 04:10 PM
digipengi's Avatar
digipengi
Bad news strikes again for my 08 MCS. I've noticed that my car burns oil with a furious passion (though I know Mini's love to eat it), Took it into the shop today after realizing I was again low on oil about 1400 miles after my last oil change. I was 2qt's low so the mechanic did some looking and recommended that I get a new short block due to blow by.
I still owe money on it and have done some performance work to it already so trade in is out of the question.
Anyone have recommendations on this matter, I am not the best with cars but want to learn what happened and how to take care of it. I saw that I can get a short block from Mini Mania for $28xx but is that the best way to go about it?
Thank you everyone in advance!
Old Jul 13, 2015 | 05:00 PM
digipengi's Avatar
digipengi
And the shop wants to charge me $3600 for labor only.....
Old Jul 15, 2015 | 04:30 PM
NB Cooper's Avatar
NB Cooper
$3600 just for labor!
Time to get another opinion and another shop IMHO.
Old Jul 15, 2015 | 05:19 PM
digipengi's Avatar
digipengi
Yeah I went and had a compression test and leak test done (different mechanic) and everything came back good (Compression was 160).
Turns out I need a new valve cover, and since I've just passed 80k it's time for a timing chain (I want to get it done before something happens).
Seems like my mini will live on!
Old Jul 15, 2015 | 06:10 PM
AZdsrt's Avatar
AZdsrt
As my dad told me many years ago, how much oil can you buy for $6,000? Good compression; keep a couple of quarts in the car, check level when ya gas up..
Old Jul 17, 2015 | 12:14 AM
Systemlord's Avatar
Systemlord
Is this your first time replacing the timing chain? I don't understand how we have such great compression with the amount of oil these Mini's not only drink and the oil coked intake valves as well!
Old Jul 23, 2015 | 02:51 PM
digipengi's Avatar
digipengi
This is the first time I've done the timing chain. I just want to get it done since I just crossed the 80k mark.
Old Jul 23, 2015 | 04:25 PM
Systemlord's Avatar
Systemlord
Make sure their installing the 5th Gen 82 mm longer tensioner, it's many times smoother than a new 4th Gen shorter tensioner. Don't worry about it being longer, it will just be in further and as the chain stretches it will be more than long enough to tension the timing chain for years to come. Most timing chains go bad long before 80,000 miles.
I think you might be burning more oil than some because of your valve oil seals, oil must be leaking down onto the valve coking right there. Then you have the oil vapor as well coking on the valves.
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
Zettinger
Aug 25, 2015 04:04 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
