R56 a button in the engine bay
Old Jul 5, 2015 | 02:58 AM
genik's Avatar
genik
What kind of button is this? Im thinking of placing an oil catch can there and the screw is used by that button!
Old Jul 5, 2015 | 04:51 AM
MIminiclubman's Avatar
MIminiclubman
I believe that is the high tech switch to tell you if your bonnet is not down an latched.
Old Jul 5, 2015 | 04:55 AM
Drivehard's Avatar
Drivehard
Yes that's the alarm switch to detect hood opening. You can move it if needed you'll need to rig a little bracket
Also. You need to wash your engine compartment. lol !!! 😎
Sent from my iPad using NAMotoring
Old Jul 10, 2015 | 06:22 AM
scf's Avatar
scf
Don't listen to him, you're engine compartment is fine. Hell, the outside of my car is that dirty consistently. I live on a dirt road, and drive an hour to work. Life gets in the way.
And yes, that is your bonnet switch.
Old Jul 10, 2015 | 06:27 AM
+1 its for the alarm.
Old Jul 11, 2015 | 04:25 PM
genik's Avatar
genik
Ok suppose its for the alarm, then if i take it out, will i still get "open bonnet" light notification?
Old Jul 11, 2015 | 05:06 PM
a2oc's Avatar
a2oc
you can switch that off in ncsexpert
Old Jul 11, 2015 | 06:41 PM
rkw's Avatar
rkw
That's a different switch at the hood latch, so yes you will still get the notification.
Old Jul 11, 2015 | 11:23 PM
genik's Avatar
genik
Where is that different hood switch located?
Old Jul 12, 2015 | 02:24 AM
rkw's Avatar
rkw
Look at where the hood latches (at the end of the hood release cable), and you should find a switch with a wire connector.
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:57 PM
blackie
Jan 18, 2017 09:56 PM
makg
Aug 21, 2015 02:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
