Navigation & Audio USB/AUX Bluetooth adapter.
Old Jun 25, 2015 | 05:35 PM
H. STGLTZ's Avatar
H. STGLTZ
Wondering if anyone makes a Bluetooth adapter that plugs into the USB/AUX so I can listen to music on iPhone 6 through blue tooth and control from steering wheel. Have adapter that plugs in but adapter doesn't fit in the new life proof cases. So looking for alternative so I don't have to remove phone from case every time I get I he car.
Have a 2012 JCW Coupe. Hope this is the right forum for this question.
Thank you
Rob
Old Jun 25, 2015 | 06:46 PM
bmrguy03's Avatar
bmrguy03
Originally Posted by H. STGLTZ
Wondering if anyone makes a Bluetooth adapter that plugs into the USB/AUX so I can listen to music on iPhone 6 through blue tooth and control from steering wheel. Have adapter that plugs in but adapter doesn't fit in the new life proof cases. So looking for alternative so I don't have to remove phone from case every time I get I he car. Have a 2012 JCW Coupe. Hope this is the right forum for this question. Thank you Rob
Viseeo makes a really good one that is compatible with our cars. I have a used one for sale if interested.
Old Jun 25, 2015 | 07:20 PM
H. STGLTZ's Avatar
H. STGLTZ
Why are you selling the one you have?
Looks like I only need the 1000 series.
Which do you have for sell and how much?
Old Jun 26, 2015 | 01:12 AM
hammerhands's Avatar
hammerhands
A lightning cable doesn't fit in the case?
Old Jun 26, 2015 | 05:29 AM
H. STGLTZ's Avatar
H. STGLTZ
Not the adapter ones. Not in the iPhone 6. Obviously the charging cable fits. But haven't found an adapter one that fits. USB/AUX that came with car was for iPhone 4. So adapters iPhone 4 female to iPhone 5/6 male which I have. It is too big. ��
Old Jun 26, 2015 | 08:06 AM
bmrguy03's Avatar
bmrguy03
I have the 1000. I'm selling because I traded my Countryman for a newer one that has the connected package and no longer needed. BMW/MINI has a medit cable available for iPhone 5/6. Why that one doesn't come standard with the car instead of the 30-pin is beyond me. I'm selling my WMA1000 for $50. I believe the lightning media cable from BMW/MINI is about $80.
Old Jun 26, 2015 | 09:27 AM
H. STGLTZ's Avatar
H. STGLTZ
So the 1000 plugs in and then phone music and such are full Bluetooth and controllable from radio and steering? That's how I'm reading the product. If you would recommend it and it works well. And will let it go for $50 shipped. I'll take it.
Old Jun 26, 2015 | 01:29 PM
hammerhands
Oh, you don't have a USB port that does audio?
They do have a Lightning to 30-pin cable.
http://store.apple.com/us/product/MD...n-adapter-02-m
[something up with the Apple Store today]
This mini branded solution is very nice, a wee expensive!
http://www.ecstuning.com/ES2745149/
Old Jun 26, 2015 | 01:37 PM
H. STGLTZ's Avatar
H. STGLTZ
I have that adaptor already. However the end for the phone does not fit into the lifeproof case for the iPhone 6. Fits case for 5 but some reason not the new one.
Old Jun 26, 2015 | 02:57 PM
hammerhands
They have that adaptor as a cable.
And this is the expensive MINI one.
Old Jun 26, 2015 | 05:28 PM
bmrguy03's Avatar
bmrguy03
You are correct. You can change tracks and what not from the radio. As far as what apps you want to play from has to be done from the phone. I loved it using to control my android phone, being that yours is an iPhone, you will have a little more features. I'm willing to do $50 shipped. Just PM if you want it and I will give you payment details.
Old Jul 24, 2015 | 01:42 PM
comport's Avatar
comport
I think there might be some confusion in this thread.
If you connect your phone to your MINI via USB (any phone, any type of cable that plugs into USB), then you can play music from your phone, and use your steering wheel controls to change tracks and browse music on your device.
If you connect your phone (or any other audio device) to your MINI using only the AUX input (looks like a headphone jack), then you can listen to your audio, but you cannot use the steering wheel controls (except volume).
If your MINI has MINI Connected, and you connect your phone to your MINI using bluetooth, then you can use the full set of steering wheel controls (audio and voice call) to control both music and phone calls.
If your MINI doesn't have MINI Connected (e.g., standard audio), then you can connect your phone to your MINI using bluetooth, and use the steering wheel controls for voice calls, but you can't listen to or control music via steering wheel controls.
There are various bluetooth-aux adapters that you can use to allow your non-Connected MINI to playback bluetooth audio through your MINI sound system. These adapters utilize the A2DP protocol to connect your phone to a bluetooth receiver, and then the bluetooth receiver connects to your sound system using AUX.
Depending on the exact capabilities of your phone and the bluetooth-aux adapter, you may be able to simultaneously connect your phone directly to your MINI for voice call functionality and also to the adapter for A2DP music playback via aux. I've been doing this with the
a2dp bluetooth adapter from kinovo a2dp bluetooth adapter from kinovo
, paired to my Lumia 925.
Old Jul 24, 2015 | 01:46 PM
comport's Avatar
comport
actually, i stand corrected- that Viseeo looks awesome. going to be checking it out..
Old Aug 2, 2015 | 09:31 PM
MarcoPolo's Avatar
MarcoPolo
Disregard.. Didn't read post entirely
navybsn
Oct 5, 2018 04:42 PM
gar56
Nov 15, 2016 06:41 AM
krohm
Sep 28, 2015 12:16 PM
DevilMeTaz
R60/R61 Stock Problems/Issues
Sep 22, 2015 05:19 AM
