R56 Coolant leaking a few drops.
Old Jun 21, 2015 | 03:21 PM
enoe01's Avatar
enoe01
I am seeing a few drops of what I believe is coolant dripping from the approximate are of the oil fill area. Obviously it's not coming from here but somewhere above it possible. Does anyone have an idea of what and where it is leaking from. I say I believe it's coolant because it's green and smells sweet although the texture is a bit like oil. Any ideas? Thanks Erik
Old Jun 21, 2015 | 08:47 PM
johne123's Avatar
johne123
Most likely the water pump. When the seal on. The shaft starts to wear you'll get a few drips. The coolants runs along the front of the engine and sometimes control arm, so it picks up a little dirt. Just went through this myself
Old Jun 22, 2015 | 01:13 AM
Systemlord's Avatar
Systemlord
This was the case before my water pump started gushing/spraying coolant out all over the place. Weeks before I did notice a few drips of coolant dripping off the front right control arm. The coolant should be blue not green, Mini coolant is blue.
Old Jun 22, 2015 | 04:27 AM
mbwicz's Avatar
mbwicz
The water pump is on the passenger side of the engine, so if you see drips on the ground near the right front side of the car, that is likely it.
The thermostat housing is on the driver side of the engine, but the transmission housing normally traps fluid from this leak. If you see drips on the ground near the center of the car, it is likely the thermostat housing.
Both of these areas are common failure points and will start leaking after about 4-5 years.
Mike
Old Jun 22, 2015 | 02:44 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 Good info
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 22, 2015 | 03:00 PM
mbwicz - is right on.
There is a common DIY here which explains the things to check out. We are pretty comprehensive.
You can read more here as we have complied it :
https://www.northamericanmotoring.co...ent-guide.html
Old Jul 5, 2015 | 04:38 PM
phenams's Avatar
phenams
Is there any other thing that would leak on the passenger side beside the water pump. ? Cuz i order a need pump when my car started gushing coolant, replaced it today n after i was done there is still a leak by the passenger side. Please any help need to get this p.o.s. back up cuz i need it for work. Thanks.
Old Jul 5, 2015 | 05:50 PM
Systemlord's Avatar
Systemlord
There's a plastic pipe that fits between the thermostat housing and to the water pump, it could be leaking at either end. Make sure both hoses that connect to the pump are not leaking, it's easy to overlook. Best thing to do is remove front right tire to get a better look at the pump area and if you can see where it's leaking from.
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
rikaro
Sep 21, 2015 06:57 AM
olson187
Sep 18, 2015 10:26 AM
mimaal
Sep 4, 2015 09:09 AM
