FS:: Lots of Audio Upgrades
Old Jun 12, 2015 | 08:14 PM
spingq's Avatar
spingq
Category: Navigation & Audio
Price: $0
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, Electrical
Location (Region): Midwestern
I have a lot of like-new audio components that I no longer need now that I've installed the Integral Audio Soundstage kit. Most of this is barely used and all is 100% functional.
-Custom universal x9331 harness bridge. Before getting my Soundstage kit, I ordered the parts to make my own x9331 T-harness. Since I didn't end up needing them, I ended up making a universal bridge that can be used for pretty much any of your 2nd gen audio needs (i.e. channel swapping or amp output splicing). All the speaker wires are labelled on both ends so you'll know which wires they lead to in stock configuration once you cut into them. I've also got a 2 channel LOC if you need one, just ask. $50
-Integral Audio amplifier mounting bracket. This is meant to mount a compact amp in the boot of an R50/53 or R56, behind the carpeted wall. I bought this on ebay before I got the full IA kit which came with one. $20
-Boss R1100m monoblock amp. Plenty of power for a 10” sub and pretty small. Includes remote level **** and speaker level inputs. PLEASE NOTE: even though it is small, it will not fit behind the carpeted sidewall of the boot. If you need installation wiring for this, please ask - I have a complete hook up kit including speaker wires. $45
-Rockford Fosgate R2s 10” shallow mount subwoofer in shallow enclosure. Dual coil 4ohm, currently wired for a 2ohm load. I powered this with the Boss amp seen above and it has plenty of output. Unfortunately, the box will not fit in a down/upfiring configuration in the boot of an R56, but it should be fine in the larger boots of Clubmans and Countrymans. $100
-Rockford Fosgate R165-S 6.5” components, including “custom” upper door mounts for replacing the 4” mid-woofers in an R5x. Basically I gutted the frames of my stock 4” drivers and screwed the tweeters on, angled to face the seats. SOLD
-Pioneer 6.5” and 4” coaxials. See the backsides for part numbers. I installed these before switching over to the components. It has been mentioned on the boards here that running dual coaxials in the R5x doors is not ideal, but these will still get you sounding better than the stock drivers. Will consider splitting these up if you don’t want both sizes. $60
-Integral Audio R56 door speaker adapter rings. Another eBay purchase I didn’t need. These will open your options up a bit for installing various speakers in the doors. 4 13/16” opening on the woofer adapters, 3 1/16” opening on the mids, 3/8” thickness. SOLD
-OEM HK tweeters from LCI R5x. These came with the A-pillars I bought for my Soundstage kit. As you can see, they have an inline capacitor acting as the crossover. I haven’t tested them, but the cones and wiring/harness plugs are all intact and I’d be amazed if they did’t work properly. If they are DOA, I will issue a full refund. SOLD
Prices are negotiable within reason, and include shipping via USPS. Please PM me with any questions or offers, thanks for looking!
Old Jun 13, 2015 | 08:40 PM
geeks2you's Avatar
geeks2you
PMed
Old Jun 13, 2015 | 08:57 PM
spingq's Avatar
spingq
Replied, and sale pending on the HK tweeters.
Old Jun 18, 2015 | 02:41 PM
spingq's Avatar
spingq
Bump, tweeters are SOLD.
Old Jun 18, 2015 | 10:51 PM
nismo4life's Avatar
nismo4life
Interested in the Amp bracket. Would you mind taking the length and width measurement for me first? Just want to make sure the Polk amp I just bought will fit.
Old Jun 18, 2015 | 11:23 PM
spingq's Avatar
spingq
12" x 6" x 3/4"
Old Jun 27, 2015 | 02:37 PM
spingq's Avatar
spingq
bump again, everything but the tweeters are still available. make me some offers!
Old Jul 6, 2015 | 05:42 PM
mcguir6799's Avatar
mcguir6799
Pmed you
Old Jul 7, 2015 | 06:54 AM
rckrzy1's Avatar
rckrzy1
I'll take the adapters.
Old Jul 7, 2015 | 01:47 PM
spingq's Avatar
spingq
PM's replied, RF components and IA speaker adapters are sold.
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
marendt428
Nov 14, 2015 10:03 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
marendt428
Aug 8, 2015 04:44 AM
