R56 how do i remove the bov?
Old Jun 7, 2015 | 11:02 PM
genik's Avatar
genik
I want to learn how to remove my stock dov in order to repair it! Is there some guide or video available?
Old Jun 7, 2015 | 11:36 PM
countrymanman's Avatar
countrymanman
It's not hard, i would look at the forge recirculation install instructions. The first part is how to take out the stock diverter. Which is removing intake tube, removing the 10mm bolt from coolent res and moving it over out of the way, three bolts, a vacuum hose(actually being on the wastegate to give a little more room), and an electrical connection.
Old Jun 7, 2015 | 11:56 PM
Systemlord's Avatar
Systemlord
What countrymanman said. I always use a bungee cord from my snake aquarium to hold the reservoir up and out of the way. I got four bungee cords holding that top piece down securely.
Old Jun 8, 2015 | 07:40 AM
Forge BOV adapter install:
http://www.forgemotorsport.com/media/fmdvmcsrev.pdf
Newest stock DV design from MINI. 11658636606
http://www.ecstuning.com/Search/SiteSearch/11658636606/ES2768088/
Old Jun 8, 2015 | 10:58 AM
genik's Avatar
genik
What exactly are the differences between the old and new stock DV?
Old Jun 8, 2015 | 11:02 AM
There were two design revisions, then the newest one above. Form the old to the new looks like the similar VW/audi DV design based off what I can see.
You could see the yellow diaphragm between the plunger and the main housing, now the end plunger is different and the diaphragm is behind the plastic housing.
Old Jun 8, 2015 | 11:05 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
This is a good thread on NAM about possible replacement DV's. Forge makes a great product. Didn't see a DIY anywhere, but it is a pretty simple job.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 8, 2015 | 01:12 PM
genik's Avatar
genik
-Luccia
Luccia, you're the greatest . Many thanks for posting in this thread that is very helpfull to me, as it describes exactly my problem!
Old Jun 8, 2015 | 01:57 PM
PelicanParts.com
Vendor
Fabulous! You're quite welcome. I'm glad I could help.
-Luccia
Old Jun 8, 2015 | 02:29 PM
That's the thread which also talks about the older part numbers, which I talked about. The forge link above has a nice how to.
Old Jun 8, 2015 | 08:54 PM
wzabrouski's Avatar
wzabrouski
Ball end 5mm works best.
Old Jun 18, 2015 | 09:53 PM
genik's Avatar
genik
I dont understand!
Old Jun 18, 2015 | 09:55 PM
genik's Avatar
genik
When i screw the dv back again, how will i know which way is the right way to place it on? Is there something to remember regarding the dv's orientation so that its mounted on correctly and not misplaced?
Old Jun 19, 2015 | 06:47 AM
That's for the head of the three screws.
That's the orientation.
Old Jun 20, 2015 | 09:46 AM
R56BrgMcs's Avatar
R56BrgMcs
Can you still put the alta bov spring in the new DV?
MasterShaftner
Nov 4, 2016 09:38 AM
The_Kid
Nov 3, 2016 06:30 PM
Crimguy
Sep 10, 2015 01:07 PM
theunlimitedone
Aug 31, 2015 08:17 PM
greekzilla
Aug 23, 2015 03:44 PM
