R56 Fog Light HELP
Old May 28, 2015 | 11:46 AM
chav's Avatar
chav
Fog Light HELP
So the other day I was installing a skid plate and noticed that my fog lights both looked bad. so I called Mini and the said it would run me $190 to buy a brand new one... I didn't want to spend about 380 for two new fog lights.
Does anybody have any ideas? or do the lights come apart to where I can buy a damaged one?
Attached Thumbnails Fog Light HELP-img_0752-1-.jpg   Fog Light HELP-img_0753-1-.jpg
Old May 28, 2015 | 11:50 AM
Yea its corroded and the reflective material is pealing off or something , must have gotten water in there at some point. They are sealed units. 63172751295
You can either get new ones. Or just upgrade to LED DRLs.
http://www.ecstuning.com/Search/SiteSearch/63172751295/
DRL LED Fogs:
https://www.northamericanmotoring.co...installed.html
Here is the DRLs if anyone is looking for them. Part # 63122338554
http://www.ecstuning.com/Search/SiteSearch/63122338554/
Old May 28, 2015 | 12:00 PM
ammodave's Avatar
ammodave
They can't be disassembled; you have to replace the entire unit. I bought a pair of used lights off eBay several yrs ago for less than $100. This pair is on eBay right now http://www.ebay.com/itm/07-13-MINI-COOPER-S-CLUBMAN-R55-R56-R57-OEM-FRONT-FOG-LIGHT-SET-LEFT-RIGHT-/251939123266?hash=item3aa8bdf042&vxp=mtr. They can be replaced without removing the bumper but it's a little tricky. The right side is not too bad but the windshield washer bottle is in the way on the drivers side. Read post 10 in this thread https://www.northamericanmotoring.co...ml#post3410142.
Old May 28, 2015 | 12:20 PM
rkw's Avatar
rkw
You didn't say whether the lights still work. If they work, or you never use the fogs anyway, I wouldn't bother.
Old May 28, 2015 | 12:38 PM
chav's Avatar
chav
The lights still work and I use them all the time. I very use my rear fog lights unless some big *** truck is on my *** then I flip the switch and watch the ******* slam his brakes.
Old May 28, 2015 | 12:42 PM
chav's Avatar
chav
Originally Posted by ammodave
They can't be disassembled; you have to replace the entire unit. I bought a pair of used lights off eBay several yrs ago for less than $100. This pair is on eBay right now 07 13 Mini Cooper s Clubman R55 R56 R57 Front Fog Light Set Left Right | eBay. They can be replaced without removing the bumper but it's a little tricky. The right side is not too bad but the windshield washer bottle is in the way on the drivers side.
Okay thanks! I will look into getting them used then finding a bright bulb for driving and fog light
Old May 28, 2015 | 08:20 PM
damncajun's Avatar
damncajun
Rear fog lights?? I need pictures
Old May 29, 2015 | 06:51 AM
Ghetto Mr Bob's Avatar
Ghetto Mr Bob
They're an option. If you had them (I'm assuming you don't have them) you'd have the toggle where the blank space is next to the passenger side window control.
Old May 29, 2015 | 07:37 AM
chav's Avatar
chav
Here are the Pictures
Attached Thumbnails Fog Light HELP-img_0759-1-.jpg   Fog Light HELP-img_0760-1-.jpg
Old May 29, 2015 | 11:04 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Typically, you can open them up and see what you can do, but probably buying a new set is the best option. Have some options here. This tech article goes up to an R53, but can't see it being much more difficult to remove on yours. Might be able to use it as a reference for removal. Good luck!
-Luccia
888.280.7799 | 6am - 5pm PST
Old May 29, 2015 | 11:08 AM
Factory rear fog lights can be added on the stock Cooper S bumper , there are black holes for the 2007-2010 version . They you will need the toggle switch and panel if you want the complete look, then a MINI dealership or someone can code it.
Old May 29, 2015 | 12:48 PM
damncajun's Avatar
damncajun
Ahhh. Guessing that's a European requirement. I like it though. Sounds expensive.
Old May 29, 2015 | 12:56 PM
Nope you can get it here in the US also from the factory.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
