Drivetrain Any reason to change my exhaust if I don’t go catles DP?
Old May 4, 2015 | 10:36 AM
JMC1's Avatar
JMC1
I’ve dropped the 2nd cat and resonator on my 2010 R57, and that didn’t get the sound I was looking for. That and I'm not a big fan of the factory tips. So now I’m thinking about a new cat-back system, but as I sit here thinking about it I’m not sure I’ll gain anything because I have no plans to go with a Catles DP.
Should I just replace the muffler, that way I get a different sound and tips? Does the larger pipe from the DP to the muffler make much difference?
And if I did just go with a muffler, which one should I look at?
Thanks..
Old May 4, 2015 | 10:54 AM
velvetcows's Avatar
velvetcows
What sound are you going for? A little elaboration on that will help.
Old May 4, 2015 | 11:05 AM
JMC1's Avatar
JMC1
Sound isn’t the big issue. I guess I’m fine with the sound I have now, it’s a little raspy, and I would prefer a bit deeper sound. I’m not looking for loud. The main thing is I just want my car to breathe better. I just don’t want to waste money on a whole new system if I don’t need to. If I planned on going with a Catless DP than I’d be all about getting the whole system but with me keeping the stock catted DP I thought the bigger pipe going to the muffler may be unneeded.
Old May 4, 2015 | 11:20 AM
Centium's Avatar
Centium
If you want to lose the rasp, I would get the resonator back on the car... Just removing the 2nd cat may be all you needed. The resonator is a straight-through design, so it really shouldn't impact performance all that much if any at all.
Old May 4, 2015 | 11:43 AM
Ovrclck's Avatar
Ovrclck
I may do that for mine as well. I won't lose the loud bangs and pops if I put the resonator back on will I? I also have 2nd cat deleted.
Old May 4, 2015 | 11:56 AM
Centium's Avatar
Centium
When I removed mine I did several test runs...
1.) Stock
Moderate pop n' burble, dumbed down exhaust sound...
2.) 2nd Cat removed. Resonator still in place.
Significantly more pop n' burble upon deceleration. More pronounced exhaust note during cold start and harder acceleration. No drone at constant speeds.
3.) Resonator and 2nd Cat removed.
Very sporty exhaust note with heavy pop n' burble upon deceleration. Cold start is a bit loud, but nothing that might wake the neighbors. Still no drone at constant speeds.
Old May 8, 2015 | 10:59 PM
Systemlord's Avatar
Systemlord
If you just want a cat back exhaust with awesome looking tips Borla is the best choice imo! The S-Type Borla Exhaust has a deeper tone than even the Akrapovic Evolution Exhaust and better tips, the tips on the Akrapovic look like a sleeper look mild. The Akrapovic has a great sound just not as a deep throaty as the Borla S-Type. You can hear the Borla better with your windows down!
Old May 9, 2015 | 07:49 AM
Grizld700's Avatar
Grizld700
I'm very partial to my NM DP-Back exhaust. It has an awesome note. Plus there is no cutting involved. Slip off, slip on. That being said, it was a little more expensive. No where near Akra, or Innotech (i think thats one).
But to your original question. No is the answer. Cat-back exhaust will do very little. Unless you get into aggressive tuning. If you're not tuning, or doing very mild tuning, I would just get your exhaust to the note you like and leave it. No reason to do a full system. Spend that money elsewhere.
Old May 9, 2015 | 12:44 PM
krashlocke's Avatar
krashlocke
The downpipe is the only part where you're really increasing the flow enough to add any noticeable power. Anything behind the downpipe is only adding noise. There's nothing wrong with that, of course... noise is cool.
sprp85
Aug 22, 2015 06:16 AM
elightbo
Aug 17, 2015 01:50 PM
FLYM1N1
Aug 16, 2015 01:17 PM
papawhiskey
Aug 10, 2015 09:31 PM
