R56 KW V2 Coilover Front Rubbing on 2010 MCS
Old May 2, 2015 | 08:39 PM
denny317's Avatar
denny317
Guys,
I searched on the forum but was hoping to get some clarity on the particular issue I am having after installing KW V2 Coilovers on my 2010 MCS.
I'm running stock 17" S-Lite wheels (+48 offset) with 205/45/17 tires.
What spacers do I need for the front so that the back of the front tires do not rub/hit against the KW springs? Plan to drop to about 1-2 finger gap. What's safe for clearance? 12mm spacers?
Would I need any for the rear? I am also running a 19mm Hotchkis rear sway bar.
Thanks.
Denny
Old May 3, 2015 | 12:32 AM
denny317's Avatar
denny317
Any help here would be much appreciated. Thanks.
Old May 3, 2015 | 12:36 AM
GEMSTER's Avatar
GEMSTER
Have a read: https://www.northamericanmotoring.co...you-using.html
Old May 3, 2015 | 01:33 AM
denny317's Avatar
denny317
Thanks. Looks like a 12mm spacer would work according to that thread.
Any particular brand you guys recommend? Or are they all about the same?
Old May 3, 2015 | 07:04 PM
GEMSTER's Avatar
GEMSTER
Just make sure the spacer is hub-centric and use proper length bolts.
Kimolaoha
Jul 5, 2023 01:04 PM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
FLYM1N1
Aug 15, 2015 11:20 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
