R56 2010 Cooper (NOT S) R56 SPARK PLUG DISASTER
Old Apr 28, 2015 | 11:54 AM
Spunky_2010's Avatar
Spunky_2010
I have watched all the videos and read everything about changing the spark plugs. Everything says I need a 14mm 12 point thin walled deep socket. I purchased one on line. It will not fit down on the spark plugs in the car. It fits the new spark plugs. I also saw one or two videos that had a 15mm socket.
Can someone please give me a little guidance on this?
Old Apr 28, 2015 | 12:04 PM
We had someone try the 14mm 12 point on aftermarket , non factory plugs here and found out someone stuck aftermarket Denso ones with a hex head not the Beru style 12 points.
We carry the factory style Beru plugs that use the 14mm 12 point socket linked.
https://www.northamericanmotoring.co...acement-2.html
So check the head of the spark plug first.
Your R56 MINI Cooper ( NON S ) replacement Plugs are here, there is a split year in 9/2009 also. They take the 14mm 12 point socket also.
http://www.ecstuning.com/Mini-2010-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Engine/Ignition/
Old Apr 29, 2015 | 01:52 PM
Bleedsblue's Avatar
Bleedsblue
When I read "spark plug disaster," I expect a broken plug stuck in the head.
Old Apr 29, 2015 | 02:11 PM
bavmotors's Avatar
bavmotors
yea this is far from a disaster
09R56
Nov 16, 2022 10:49 AM
Trevor413WC50
Aug 18, 2015 10:38 AM
Aug 12, 2015 01:24 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
Accessory Products
Aug 11, 2015 12:19 PM
