R56 accessport maps
Old Apr 25, 2015 | 12:08 PM
ShadyCoop's Avatar
ShadyCoop
accessport maps
Does anyone have any stage 1 maps available to email me? The only options on my AP are for upgraded FMIC, which I do not have. All help is appreciated!
Tyler
Old Apr 26, 2015 | 05:34 PM
mbwicz's Avatar
mbwicz
Give your ECM number (like H810B) and if you are an automatic or manual. I have some nice automatic tunes I would be happy to share.
Mike
Old Apr 27, 2015 | 07:58 AM
ShadyCoop's Avatar
ShadyCoop
accessport maps
BUMP my car has GB02B ECU. only maps from the same ecu will work. please help! I want to be able to use my $ 300 investment!
Old Apr 30, 2015 | 07:44 PM
oldbrokenwind's Avatar
oldbrokenwind
Song & dance --- couple years ago, a dealer upgraded my ECU software from H520B to H810B. Same ECU just different software. All I needed to do was get my custom SW re-named to the new #. Easily done when AP was still in use by tuners.
I'm guessing the number you have, GB02B is an ECU number, not a software number. You should be able to use the AccessPort Manager computer program to determine what software number series you need. I hope this program is still available. Maybe not being updated, but still available. It's pretty handy for maintaining AP logs, files, etc.
Have you plugged your AP into your computer yet?
Old Apr 30, 2015 | 07:49 PM
ShadyCoop's Avatar
ShadyCoop
Yeah I plugged it in, and used the Accessport Manager to update the AP to the latest firmware. How would I go about renaming the software(map)? Would that cause any problems with my ECU? Like I said I got some maps from someone but it was a different ECU, so if I could do this it would be extremely helpful.
Old May 1, 2015 | 08:57 AM
mbwicz's Avatar
mbwicz
Did you actually try installing the tune? One of the first things that the AP does is back up your existing tune. If the tune is not compatible with your ECU revision, then you can uninstall it.
Have you tried calling Alta?
Mike
Old May 1, 2015 | 09:58 AM
ShadyCoop's Avatar
ShadyCoop
Mike
yeah I tried installing it and it was just greyed out on tscreen(the one you gave me) and the ones that weren't greyed out required a FMIC. I called Alta and they told me I'm basically screwed until I get a bigger FMIC. this is what they said.
"Tyler,
Sorry to hear about the tune. We had limited tunes available for the automatic, so if you have a rare ECU, we may have only made just a few tunes for your car. I’d recommend uninstalling the AP from your car, then running an update using the AP Manager. You can download the AccessPORT Manager here: http://www.cobbtuning.com/products/s...ssport-manager
Once you run the update it’ll install the latest firmware, which might include some new maps. Then try reinstalling the AP to see if there are more maps available. The maps will only show up when you plug the AP into your car. If there is just a normal stage 1 map, you’ll want to install that.
If there is only the FMIC map available still, then we wouldn’t have another map available, sorry about that. On some rare ECUs, we only made maps for what an individual customer that had the ECU needed. If you have any more questions, let me know, thanks!"
I followed his instructions and sadly yielded the same problem I was having before.
Old May 1, 2015 | 10:35 AM
mbwicz's Avatar
mbwicz
The way that I see it, there are 4 options:
1. Wait and see if anyone has a map for your ECU.
2. Call the dealer and see what they would charge to update your ECU. Supposedly the later updates included a torque steer reduction. Confirm which revision they would update to.
3. Cut your losses and use a different tuner.
4. I would also try running the FMIC map to see if they shift well. Unless you drive the car very hard for long periods, it should be OK to test. Then you can decide if it is worth picking up a FMIC and keeping the AP, or going to a different tune.
Mike
Old May 1, 2015 | 03:09 PM
oldbrokenwind
Renaming a map requires an AP tuner software program --- the only way I know of to modify / edit an ECU map. Mine was done via email, and all it took was to change the 5 character map ID prefix. The only AP tuner I know of is Ziptie Dynowerks, located just outside Salt Lake City. I worked with Ryan for my last dyno tune, but others there may be familiar with the Mini AP SW. Contact info is on their website.
I just checked my AP map at the OBD connector, looking for the map prefix (H810B). It wasn't shown. The only place I can find this prefix is on the AP Manager, searching for maps. It would be helpful if you would verify your ECU map prefix for us (me). Ignore any that are greyed out on the AP, they are obviously not compatible. EDIT: Sometimes I can't do anything right --- the map ID will show on the AP, I just didn't read far enough. Select the "TUNE" screen and look at the current map. It should be part of the description.
Finally, if you don't intend to go "all out" with upgrades, I strongly suggest you forget about the AP and go with one of the other popular tuners. Especially if you have a unique ECU. Finding maps to convert can be a pain --- as you're discovering. To go "all out", Ziptie can tune it for you. Might be a really long drive to get there, but it will be worth it.
Old May 1, 2015 | 03:50 PM
ShadyCoop's Avatar
ShadyCoop
My ECU is a GB02B. I do plan to go all out with upgrades. I think it looks to me like I'll just have to get a larger FMIC, which I was going to do eventually anyways. I just hate waiting to use things! Thanks for the help. I'll contact them and see if they can help me out more.
Old May 1, 2015 | 03:54 PM
ShadyCoop's Avatar
ShadyCoop
Mike
The dealer closest to me said they don't do that unless its causing the car a problem. I might try and find a tuner that uses the AP software still. Maybe the one the previous commenter suggested does. Thanks for the help Mike
Old Jun 26, 2015 | 09:08 AM
ShadyCoop's Avatar
ShadyCoop
So I'm reviving this thread because I just installed my new, bigger FMIC and I'm still having the exact same problem as before. When I run the stage 1 FMIC 92 oct, my car goes up to 5000 rpms just fine and then it jerks hard, loses all power and then regains it until it shifts into the next gear. Then it does that in every gear. I got the AP used, so it wasn't nearly as expensive as new, but I'd like to use things that I spend money on. Any help would be appreciated.
Thanks,
Tyler
Old Jun 27, 2015 | 04:31 AM
Ex-ms3's Avatar
Ex-ms3
data log
Please post a full wot data log,,,,
Old Jun 27, 2015 | 04:47 AM
ShadyCoop's Avatar
ShadyCoop
I'm sorry I'm fairly new to all this tuning software stuff.....what is a WOT data log? Is it just a compilation of all the data logged? Is there a special way I should do this? Thanks for bearing with my lack of knowledge...
Tyler
Old Aug 6, 2015 | 10:25 AM
ShadyCoop's Avatar
ShadyCoop
Data logs
Hi everyone,
I know its been a while since I started this thread, but I have yet to find a solution to my problem. I've been busy lately, but I managed to log some data! Attached are two logs. Log 51 is a 0-whatever pull with the stage 1 FMIC map flashed, with a lot of idling at a stop light and Log 52 is a 0-50-ish pull with the stock map flashed.
Thanks,
Tyler
File Type: csv
File Type: csv
Old Feb 16, 2016 | 01:58 PM
davrudy's Avatar
davrudy
anyone have any maps for an automatic H910B?
Old Feb 16, 2016 | 03:45 PM
mbwicz's Avatar
mbwicz
Yep, PM me your email and I'll send you what I've got. 92 octane with and without FMIC.
Mike
Old Feb 18, 2016 | 07:10 AM
davrudy's Avatar
davrudy
thanks!
that map is working out very nicely! no throttle/shifting problems at all
Old May 8, 2016 | 11:39 PM
Are56Marek's Avatar
Are56Marek
Just got a accessport for my 09 mcs..
Anyone have any maps without Fmic?
Have catless dp. Exhaust. Intake.
Will be a min. Till i get a intercooler.
Old May 9, 2016 | 03:36 AM
mbwicz's Avatar
mbwicz
Manual or auto? For manual there should be stage 1 maps already loaded. For auto pm me your email and I'll send you what I have.
Old May 9, 2016 | 09:58 AM
Are56Marek's Avatar
Are56Marek
Its manual. And on the accessport it has he stage 1 maps but they all say no aftermarkets parts except larger intercooler..or no aftermarket parts 92oct
IQRaceworks
53
Jun 28, 2024 07:29 AM
RIchard Nguyen
Southern California
Feb 18, 2016 02:27 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
NeonLed
Sep 15, 2015 02:48 PM
ShadyCoop
Sep 12, 2015 10:40 PM
