R50/53 Koni FSD Install
Old Apr 23, 2015 | 06:08 AM
wilkrod's Avatar
wilkrod
Koni FSD Install
Hi All,
Was wondering if anyone who has done the Koni FSD/Ireland Engineering strut mount install could walk me thru the steps.
I have an 02/2002 MC and found out I will need the updated sway bar end links. I have taken apart one of the old struts, and inspected all the original parts, the bump stop, spring perch rubbers, and gaiter all appear in very good shape.
So do I just reuse all the original hardware, add the IE strut mount, and zip it all up?
Many thanks for any details anyone can provide.
Jeff
Old Apr 23, 2015 | 06:16 AM
IQRaceworks's Avatar
IQRaceworks
Originally Posted by wilkrod
Hi All,
Jeff
Yep, that's pretty much it.
Old Apr 23, 2015 | 06:25 AM
Aspen's Avatar
Aspen
They are detailed write ups in the how to section with step by step and pictures. I found the most challenging part was getting the front strut back into the hub carrier. I needed to keep the spring compressed and swear a lot.
Old Apr 23, 2015 | 06:46 AM
Fly'n Brick's Avatar
Fly'n Brick
If you haven't already, strongly consider replacing the strut tower bushings and adding strut tower defenders while you have things broken down. The bushings are a wear item usually needing replaced at around 50 to 75K
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
Emnotek
Aug 13, 2015 05:47 PM
