R50/53 Part number ID help
Old Apr 20, 2015 | 10:03 PM
Mib4840's Avatar
Mib4840
Part number ID help
I need your help. I have been searching RealOEM for the front mounting hardware of the intercooler cover on an 04 R53 JCW. I have gone to the dealer and what they give me does not match what is on the car. It looks like I have a really long nut/spacer that is missing. Can someone tell me or post a photo of the front mounting hardware so I know what I'm looking for?
Old Apr 21, 2015 | 04:40 AM
JABowders's Avatar
JABowders
Veteran: Army
Also need to know what month your car was assembled ..
I refer to the image is this the hardware you are talking about?
Motor on!
Old Apr 21, 2015 | 07:26 AM
Mib4840's Avatar
Mib4840
I could not find that diagram anywhere. My R53 was built 09/03. If you look at front right corner of my cover you see the black bolt that goes down through the top. If you look close to the bottom there is a silver tall looking "nut" that no one seems to know anything about. I need the bolt and nut. I'm wondering if the previous owner lost the hardware and just came up with a solution. Thanks for the help!
Old Apr 21, 2015 | 03:03 PM
MINIAC's Avatar
MINIAC
RealOEM - R53 Charge-Air Cooler
Old Apr 21, 2015 | 04:47 PM
Mib4840's Avatar
Mib4840
Thank you guys for the help!!! I ended up having a broken bracket and missing screw. Both are on order and will be here Friday.
Old Apr 21, 2015 | 07:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Glad you found them. We have used ones if you need in the future.
Old Apr 22, 2015 | 11:13 AM
That long tube bolt (silver ) comes on the intercooler: Not a separate part. You can see it at the top of the intercooler bracket.
http://www.ecstuning.com/Search/SiteSearch/11651515368/
Number 3 is the support brackets: 17517511947
http://www.ecstuning.com/Search/SiteSearch/17517511947/
#4 is the bottom bracket with a bonded nut. 17517515798
http://www.ecstuning.com/Search/SiteSearch/17517515798/
#6 is that long bolt. 17517552372
http://www.ecstuning.com/Search/SiteSearch/17517552372/ES39173/
#7 07130782486
http://www.ecstuning.com/Search/SiteSearch/07130782486/
Hope that helps for reference in the future.
Old Apr 22, 2015 | 01:33 PM
Mib4840's Avatar
Mib4840
Thank you ECS. looks like I may have to fabricate something for it.
Old Apr 22, 2015 | 07:10 PM
Mib4840's Avatar
Mib4840
Jerry at EuroTechs was able to provide me with the parts that I needed. Thank you Jerry!
If you are ever in the Phoenix/Tempe area and need a MINI mechanic stop by EuroTechs. I've taken my car to him several times and am very happy with their work.
Old Apr 24, 2015 | 09:54 AM
You are welcome.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
absolutcamper
Aug 24, 2015 12:27 PM
nomar116
Aug 21, 2015 04:36 PM
xraycat
Aug 15, 2015 06:43 AM
