R58 Rear Sway Bar Options
Old Apr 15, 2015 | 07:37 AM
scf's Avatar
scf
So, I'm getting a rear sway bar for the R58, it's just a matter of which one. I'd prefer an adjustable one, as I'm looking to do some SCCA tracking on the side.
Alta, H&R, etc...
which one? I'm leaning towards a 22mm adjustable.
Thoughts?
Old Apr 15, 2015 | 01:27 PM
jkapinos's Avatar
jkapinos
I like the NM 22mm
Old Apr 15, 2015 | 01:29 PM
mbwicz's Avatar
mbwicz
To the best of my knowledge, all of the aftermarket bars are adjustable. I have a 25.5 mm H-sport bar on the middle setting. This one is tubular, so it is pretty light, but stiffness is supposedly the same as 22 mm bars.
Is the rest of your suspension stock? Does color matter to you (H-sport is black, NM is blue, Alta is red)?
Have fun,
Mike
Old Apr 15, 2015 | 01:41 PM
Grizld700's Avatar
Grizld700
I would gladly recommend the H-Sport Competition RSB. I have it and love the thing. It has roughly the same stiffening on its 3 settings as a 22mm, but this one is hollow so it helps keep added weight down.
Old Apr 15, 2015 | 03:05 PM
Charlie Victor's Avatar
Charlie Victor
I've got the nm bar on mine, with no complaints.
Old Apr 15, 2015 | 07:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Go with the Hsport Comp sway bar it is by far the best. It only weights 5.5lbs vs a solid bar at 14lbs so you don't add any weight. But it has the nicest bushings as they have a good grease channel to hold the grease in and small steel brackets with zerk fittings that mount it. The larger aluminum brackets are much harder to install as you can't put a box end wrench on them so you have to drop the subframe more. We've been using the Hsport comp bar on all my personal cars and is by far the one we install the most due to it's high quality and reliability.
http://www.waymotorworks.com/h-sport...-sway-bar.html
Old Apr 16, 2015 | 08:56 AM
scf's Avatar
scf
Thanks Way! That's what I ordered: Order id: #19994
Thanks for all the above input!
Old Apr 16, 2015 | 09:01 AM
WayMotorWorks
Vendor
Awesome, it shipped yesterday so you may get it tomorrow.
Thank you.
W0TM8
Dec 19, 2019 07:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
