sunroof malfunction
Old Apr 14, 2015 | 08:32 AM
damncajun's Avatar
damncajun
sunroof malfunction
Got this code and motor comes on for about a second then quits. The sunroof will move slightly. Can't tell if the motor needs to be replaced or if the track and rollers are off or need lubrication. If the motor was bad would it not work at all? Ideas...
https://docs.google.com/file/d/0B0ym...p=docslist_api
Old Apr 14, 2015 | 08:41 AM
Steve Kay's Avatar
Steve Kay
Originally Posted by damncajun
Got this code and motor comes on for about a second then quits. The sunroof will move slightly. Can't tell if the motor needs to be replaced or if the track and rollers are off or need lubrication. If the motor was bad would it not work at all? Ideas... https://docs.google.com/file/d/0B0ym...p=docslist_api
Try this: https://www.northamericanmotoring.co...975-post7.html
Old Apr 14, 2015 | 04:14 PM
mtechnik2's Avatar
mtechnik2
Excessive outside temps tend to cause issues when opening. Try again when cooler outside.
Old Apr 14, 2015 | 09:37 PM
RadioFlyer's Avatar
RadioFlyer
Still under warranty? Dealer can readjust it. Happened to mine. They had to replace the cassette in the end.
PsychoRallye
21
Feb 17, 2019 06:08 AM
ian260
Mar 29, 2017 06:08 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Jim Ferrell
Oct 6, 2015 08:09 AM
