R56 tried to seafoam my car, snapped the pcv hose. how hard to replace?
Old Apr 1, 2015 | 12:55 AM
rx7ven's Avatar
rx7ven
hi,
i was trying to help my gf seafoam her 2007 mini cooper S because there was carbon buildup and i accidently snapped the pcv hose.
http://www.ecstuning.com/Mini-2007-C...16A/ES2138963/
i feel really bad and want to fix it for her asap. im no mechanic, from the looks of the picture, it seems pretty easy.... just plug and play? but how do i go about accessing the back-end? do i have to bring it to a shop?
Old Apr 1, 2015 | 05:16 AM
The front side on the valve cover is easy. The rear you will have to snake back through and its on the driver side of the intake manifold. You will have to take the intake air box out to reach this easier. They pinch and snap on on each end .
Vent Hose 11157605186
http://www.ecstuning.com/Search/SiteSearch/11157605186/
Old Apr 5, 2015 | 12:58 PM
SteveJ's Avatar
SteveJ
If you can't see where it goes, I'd start removing intake/breather hoses and such to give you access. As long as you don't have to pull the intake you should be fine. Just be mindful that there are a bunch of electrical and vacuum connections down there.
I snapped mine while pulling the head. It was fairly brittle. I hope the new one is a little more pliable. That's actually the next step (intake install) on my head replacement job in process.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
eliseo1981
Jan 28, 2021 02:45 PM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
KrisMiss
Jan 3, 2016 02:02 PM
