R56 Purchased used 12 MCS, looking for advice
Old Mar 26, 2015 | 05:32 PM
r56sss's Avatar
r56sss
Hello all, new to this forum, but not to minis, had a 10' MCS that I loved but traded when I had my son, I only had 15k on it when I traded. Now I got back into a certified used 12' with 40k miles. Haven't found anything wrong with it and it drives great. First night I dropped the oil and checked the MT fluid. Fluid looks good but I'll probably drain and replace it with redline MTL. Other fluids look good and brakes and tires look good, clutch seems to feel good.
Is there anything I should be doing maintenance wise at this mileage?
I was planning on seafoaming the motor, is this recommended on the N18 engine?
Was the clutch built any differently with the n18 motor? What kind of clutch life are people seeing?
Also it seems the n18 engine seems to be better built in that the death rattle doesn't occur, pistons have been corrected, pcv system updated.
Is there any other major gotchas with the car that preventative maintenance will prevent, that I should do?
sorry for the long post,
thank you all very much
Jeff
Old Mar 26, 2015 | 05:39 PM
AZdsrt's Avatar
AZdsrt
We have a '12 MCS with about 40k miles, bought it a couple of years ago. All I've done is have the oil and filter changed every 5-7k miles. Other than that, just the usual stuff (filters, wipers, tires, etc).
Old Mar 26, 2015 | 08:23 PM
r56sss's Avatar
r56sss
After more research, seafoam don't seem to do much. Looking into a media blaster setup to use with my 70 gallon compressor.
Anything else that should be done to the car?
Old Mar 27, 2015 | 07:41 AM
The carbon build up looks like it happens on the older N14 2007-2010 engines with higher mileage, have not seen it much on the N18 engines. Take a peak at the intake inlet on the head side , you will have to unbolt the composite plastic intake manifold to see it on the head side.
Carbon blasting is the correct way to clean it. Great DIY here.
https://www.northamericanmotoring.co...-cleaning.html
Old Mar 27, 2015 | 04:02 PM
DOtheDEW's Avatar
DOtheDEW
i have 55k miles on my n18 and no carbon build up, also I'm not going to lie, i drive very spirited and my clutch is perfectly fine... got the car brand new. but clutch life is mostly up to the driver
Old Mar 27, 2015 | 04:57 PM
The Patagonian's Avatar
The Patagonian
As its a 2012 make sure you check the wiring harness/oil sensor on the back of the sump.
https://www.northamericanmotoring.co...-check-it.html
Kimolaoha
Dec 5, 2020 09:32 PM
dyeLucky
Sep 11, 2015 10:41 AM
smarsha11
Aug 24, 2015 06:03 AM
massmini03
Aug 12, 2015 11:19 AM
dyeLucky
Aug 7, 2015 07:10 AM
