JCW Rev limiter JCW engine...........
Is it possible that the clutch slips at about 6500 rpm in 1st and 2nd gear because it is a dual mass unit? Is is just the engine cut off?
I have been told that the clutch is supposed to be stiffer than the S and more performance oriented.
The engine seems pretty much flat about torque above 6000 rpm.
It is the reason I am wondering if it is related to the dual mass clutch.
The problem is more about engine torque and power at high speed without exhausting the hell from it.
When you break traction with a front wheel drive car, you should feel it in the steering. It will go light or it will move one way or the other depending if one wheel or both are slipping. If the clutch slips, the feel of the steering should not be effected.
What you may have to do is drive another MINI with a manual transmission for reference...
Typically though, clutch slippage is felt more at low speeds, in a lower gear with a lot of throttle opening. That's when you are attempting to put more load through the clutch.
