JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Rev limiter JCW engine...........
Old Mar 23, 2015 | 07:20 PM
dube53's Avatar
dube53
Is it possible that the clutch slips at about 6500 rpm in 1st and 2nd gear because it is a dual mass unit? Is is just the engine cut off?
I have been told that the clutch is supposed to be stiffer than the S and more performance oriented.
The engine seems pretty much flat about torque above 6000 rpm.
Old Mar 24, 2015 | 09:12 AM
TheBigNewt's Avatar
TheBigNewt
The engine cuts at 6500 rpm. My 1988 BMW did that. Power flattens out near redline. Sounds normal to me.
Old Mar 24, 2015 | 05:48 PM
dube53's Avatar
dube53
Thanks for your reply. Mine is a stick shift and in some ways brutal when changing gears at high rpm. I cannot compare with an automatic transmission.
It is the reason I am wondering if it is related to the dual mass clutch.
Old Apr 28, 2015 | 04:40 PM
flatlander_48's Avatar
flatlander_48
When a clutch slips, you'll see a rise in the engine revs (assuming you hold the throttle steady). It would be very similar to breaking traction on slippery pavement.
Old May 1, 2015 | 06:27 PM
dube53's Avatar
dube53
It is very easy to break traction with the 6 SP JCW Coupe in lower gears at 6000 RPM while driving below 50 MPH.
The problem is more about engine torque and power at high speed without exhausting the hell from it.
Old May 1, 2015 | 11:11 PM
flatlander_48
When you break traction with a front wheel drive car, you should feel it in the steering. It will go light or it will move one way or the other depending if one wheel or both are slipping. If the clutch slips, the feel of the steering should not be effected.
What you may have to do is drive another MINI with a manual transmission for reference...
Typically though, clutch slippage is felt more at low speeds, in a lower gear with a lot of throttle opening. That's when you are attempting to put more load through the clutch.
theblackfalcon
Oct 11, 2015 09:49 AM
Cutelildevil666
Sep 12, 2015 09:36 PM
bjcarter2
Aug 31, 2015 04:03 PM
wind715
Aug 11, 2015 07:56 AM
