R56 Rebuild continues
Old Mar 22, 2015 | 04:37 PM
auto-pioneer's Avatar
auto-pioneer
Rebuild continues
Got the engine removed and striped down, replaced the exhaust valves and resurfaced the rest, everything was looking good until I turned the head over and found asmall steel bee bee on my bench, I know it came out of a hole in the head but which one? anybody run across that before?
Old Mar 22, 2015 | 04:51 PM
SPRINTCARS's Avatar
SPRINTCARS
Send me a photo. Ive got a couple heads we can come pair photos of
Old Mar 22, 2015 | 04:56 PM
auto-pioneer
Will do tomorrow, Thanks
Old Mar 22, 2015 | 04:58 PM
SPRINTCARS's Avatar
SPRINTCARS
My girl just sent me a photo. Im at work. It appears theres only one ball that plugs a hole. And its located over by the head bolt that outside the head by itself. On the back side or intake side of the head.
Old Mar 22, 2015 | 05:41 PM
auto-pioneer
hope you can see the pic, you can see the 2 bearings in the holes they are larger then the one I found, the only other hole is the one with the cut out around it, I hate to put in the wrong place.
Old Mar 22, 2015 | 05:55 PM
SPRINTCARS's Avatar
SPRINTCARS
No photo
Old Mar 22, 2015 | 06:00 PM
SPRINTCARS's Avatar
SPRINTCARS
Look at the head gasket relative to that hole. Then look at the block. See if that other is a drain hole. Send a photo of the ball bearing as well. If you decked that head enough to knock that bearing out, it got chopped pretty good.
Old Mar 22, 2015 | 06:01 PM
SPRINTCARS's Avatar
SPRINTCARS
Stick a clothes hangar in the open holes and see where it pops out.
Old Mar 22, 2015 | 06:17 PM
SPRINTCARS's Avatar
SPRINTCARS
These are the two spots
Old Mar 22, 2015 | 07:51 PM
auto-pioneer
mini head
Thanks for the pic. I posted a pic of the head in my gallery, Mine has those two ***** still in it, I'm thinking maybe the hole streight down from it in the pic. with the bevel cut around it
Old Mar 22, 2015 | 07:53 PM
auto-pioneer
Also thinking it may be a check valve to keep oil in the head when shut off.
Old Mar 22, 2015 | 07:54 PM
SPRINTCARS's Avatar
SPRINTCARS
Ill look at my head when i get home. I'll be home in about 40 minutes. Pm'd
Old Mar 22, 2015 | 08:30 PM
auto-pioneer
That would great Thanks, I'll give you a call.
Old Mar 28, 2015 | 12:17 PM
auto-pioneer
All was for not, my buddy where I took the head apart has a tool repair shop and I think it was a stray bee bee that I found,none were missing from the head> Thanks for all the help.
scfiveo
Sep 27, 2019 02:27 PM
Fordgt4
Oct 10, 2015 10:42 AM
navybsn
Oct 4, 2015 03:27 PM
Sailorlite
Oct 1, 2015 06:46 AM
SneedSpeed
Sep 10, 2015 07:22 AM
