Can curbed wheels be repaired?
Old Jul 23, 2004 | 08:42 AM
kyriian's Avatar
kyriian
Hi
after driving around with some new rubber my new wheels have begin to take quite a beating from my....... abuse
i was wondering if curbed wheels that have scratches on the outside be repairable... can someone possibly sand off the corners so therefore it wouldnt look so bad?
btw, my wheels are cast wheels
Old Jul 23, 2004 | 10:14 AM
kenchan's Avatar
kenchan
You can buff it out to a degree, but really depends on how deep the
scuffs are. It will look better than just leaving it alone though. If you
have deep scuffs (like chunks missing), you're probably better off
getting a new wheel or have it professionally repaired.
I usually use a 200grit to get the burrs off first. (mask off the area so
you don't enlarge the scratch). Then use 400 grit to smooth out, and
for polished rims, finish off with 1500grit wetsand it and clearcoat.
Sometimes it's better to use 1000grit depending on how polished or
brushed the wheel is.
Wait about 2 hours and while the clearcoat is still soft, I use ScratchX
to blend in the clearcoat into the wheel's original finish. Then let
dry for a few days and use either compound or ScratchX again to
polish it up even more to blend it in.
If you have painted wheels, try getting similar enamel paints at a hobby
shop and mix to get a close match. For me, flat paint is easier to mix
than gloss. I just use clearcoat at the end to get the glossy finish.
Old Jul 23, 2004 | 10:48 AM
Alex@tirerack's Avatar
Alex@tirerack
repair
Wheel collision center - 800.292.7467
7286 penn dr.
Bath, Pa 18014
Old Jul 23, 2004 | 10:53 AM
pbraun's Avatar
pbraun
If around Westchester county, New York, call : George or John at The Wheel Guy, specialists in wheel straihtening and refinishing, curbing, etc....
excellent work, reasonable prices! 914-224-6387
Old Jul 23, 2004 | 11:03 AM
Rick-Anderson's Avatar
Rick-Anderson
Wheel repair shops will turn the wheel in a lathe and reprofile the edge to the correct shape. Expensive, though. I need to have mine done.
Old Jul 23, 2004 | 11:25 AM
CirqueDeSoMini's Avatar
CirqueDeSoMini
the guy at classic auto campus quoted me $180 each for 17" s-lites ( i think they may be refurbished )
Old Jul 23, 2004 | 04:21 PM
kyriian's Avatar
kyriian
thanks for the advice
the scratch was not too deep, just large.. no chunks missing... probably will try buffing it out...
btw, the outside rim of my rim is polished so likely i wont get that shine back will i?
Old Jul 24, 2004 | 07:21 AM
kenchan's Avatar
kenchan
If you wetsand with 1500 grit, it will shine up real nice... :smile: (sometimes
you need to use lower grit because it will shine up so much that it looks like
stainless or chrome).
I had a SSR IntegralA2 repaired at www.wheelcollision.com once.
They did a good job. Nice hard powdercoat too. :smile:
Old May 13, 2018 | 03:05 PM
TRAVR6's Avatar
TRAVR6
Old post but in case people search in the future.
https://youtu.be/9WQiqYlpxoY
Old May 13, 2018 | 09:21 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
As long as the wheels are not cracked and still round they can easily be refinished and painted or powdercoated.
Some alloy wheels have a clear coat so sanding will not match but depending on your wheel design that may not matter. The clear coat from some companies will crack over time and look bad.
woodstudio
Mar 15, 2020 08:28 AM
Steeroidz
Aug 29, 2018 07:41 AM
SosoMINI
Nov 22, 2015 03:17 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
sabjcw
Aug 14, 2015 07:40 AM
