N12 Throwing Codes After Start Idle
Old Mar 21, 2015 | 08:07 AM
pmarketingsales's Avatar
pmarketingsales
My first post here. Love Mini's! They rip! Fun cars to drive!
Having issue with my Cooper. 2008 N12 engine.
After you start it the engine seems to run in a high idle mode for a moment to warm the engine. It seems that the moment it drops out of that high idle it doesn't like what it sees and it throws the code P0015 or P0014.
Pulled off valve cover and checked timing chain tension, guides, the timing, and every thing seems to check out ok. Both vanos solenoids are good, as well as their wiring to the ECU. It looks like the timing chain and Exhaust cam adjustment unit have been changed. The chain tensioner is also the updated version with the dimple in it.
I also checked pressure to depress the tensioner and it took a 35lb dumbell to depress it.
Anyone have any ideas as to why the computer is sensing advanced or retarded timing on my exhaust cam? Car has 100k miles on it.
I'm lost on this one.
Oh cam sensors are both good also, as well as their wiring to ECU.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
mdutton11
14
Oct 26, 2015 01:47 PM
patrioticmini
Aug 20, 2015 10:54 AM
massmini03
Aug 12, 2015 11:19 AM
Lt. Dan
Aug 10, 2015 08:23 AM
