R50/53 Warning on Monroe strut mounts
Old Mar 12, 2015 | 06:45 AM
jdblep's Avatar
jdblep
Replaced both strut mounts less than one month ago, and went the cheap route--Amazon purchase of 2 Monroe 906983 Strut mounts. Noticed yesterday a strange noise upon acceleration/braking like a creaking door, and opened my hood to find this:
Old Mar 12, 2015 | 06:50 AM
Helix13mini's Avatar
Helix13mini
I just posted on this in another thread. Avoid them like the plague. The factory strut mounts are way more expensive, but you won't be re-doing the job in three months. I finally learned my lesson after eating a few warranty jobs.
Old Mar 12, 2015 | 07:24 AM
jdblep's Avatar
jdblep
Thanks Helix, is there a good place to buy the better mounts, or another brand such as moog? Also saw your other post mentioning your M coupe. Just sold my m roadster (to enthusiast auto), and bought the mini!
http://enthusiastauto.com/qsearch/?i...1#.VQGhZ47F98E
Old Mar 12, 2015 | 08:18 AM
nkfry's Avatar
nkfry
We had a customer install the Monroe mounts previous to visiting us, we put the car on the lift and the mount literally fell apart. Bearing came out of the rubber isolator, as Eric said; pay more now, save more later.
Many vendors have the MINI aftermarket strut mounts on hand, if Eric doesn't have them on hand we have them in stock and would be glad to help out.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Mar 12, 2015 | 08:20 AM
Vkng's Avatar
Vkng
http://www.waymotorworks.com/oem-fro...rut-mount.html
They are typically $122 each from the dealer http://parts.miniofkennesaw.com/prod...306758309.html
I would consider getting reinforcement plates while you're at it to avoid mushrooming on the towers, but they can be installed from up top and can be done later.
Old Mar 12, 2015 | 08:35 AM
AndyPWR53's Avatar
AndyPWR53
When I did mine I believe I used Sachs or Lemforder. You can pick them up pretty cheap ($40-50) and I'm pretty sure one of them is the manufacturer for the OE part itself.
Old Mar 12, 2015 | 09:20 AM
Helix13mini
Those guys are the biggest M Couple dealers, I believe. They are really driving demand and price for those cars. If you're in Ohio, and local, Classic Auto dealership has some pretty sweet prices on OEM parts as well.
Old Mar 12, 2015 | 10:31 AM
Have heard from a couple people about the Monroe ones.
We have the mounts here, used the lemfoder ones with no issues. : 3/2002+ gen 1
http://www.ecstuning.com/Search/SiteSearch/31306778833/
Old Mar 13, 2015 | 12:39 PM
jdblep's Avatar
jdblep
I noticed today that the other side is starting to separate as well. Hard to believe that these have only been on one month! Just ordered the Lemforder mounts, and hopefully Amazon will let me return the crappy Monroe mounts.
Old Mar 19, 2015 | 12:18 PM
Did you get them replaced yet? Sorry to hear both are bad. I replaced them in pairs before, just to be sure , a good visual at the top for the cracking let you know.
Good luck.
Old Mar 19, 2015 | 12:45 PM
jdblep's Avatar
jdblep
Received the lemfoder mounts a few days ago. Planning on doing the replacement this weekend. Amazon did refund the entire cost of the monroe mounts.
Old Mar 19, 2015 | 12:46 PM
Good , thanks for the update.
Old Mar 19, 2015 | 03:21 PM
DixonL2's Avatar
DixonL2
I did a review on Amazon on these, same issue, replaced (4) of them (2 on daughter's car, (2) on mine) and (3) of them didn't make 500 miles. AVOID MONRO MOUNTS.
Old Mar 19, 2015 | 05:58 PM
IQRaceworks's Avatar
IQRaceworks
Don't forget about the Ireland Engineering mounts.....they are pretty beefy
Old Mar 20, 2015 | 05:40 AM
minsanity's Avatar
minsanity
Sachs, Boge & Lemforder are all under the ZF umbrella, identical & OE manufacturers.
Old Mar 21, 2015 | 06:24 PM
jdblep's Avatar
jdblep
Replaced the Monroe mounts today with Lemforder mounts from ECS, good thing i bought a spring compressor from harbor freight. First thing that i noticed was the Lemforder mounts upward deflection was roughly half that of the Monroe--definitely a good sign. Unfortunately this didn't solve my creaking upon accel/decel, i am wondering if a bushing is rubbing. I did pressure wash the underside of the car when i replaced a burst PS hose (about the same time this starting happening)--anyone have any ideas? The only way to reproduce the noise (pass-side front), is driving the car. Pushing up/down on the front of the car = no noise.
Old Mar 22, 2015 | 02:07 PM
Nicefeet's Avatar
Nicefeet
Did you change the sway bar endlinks at the same time?
I have found that Moog aftermarket sway bar end links will rub on the passenger side axle. They were made too thick which they try and use as a selling point, but it don't mean crap when it don't work. This cause my car to making a rubbing sound under decal and accel at random times.
Also is anyone else finds this thread avoid Moog upper strut mounts, those are garbage also. Mine didn't even last a couple of months and all I got was a finger from Moog and Rock Auto
Old Mar 23, 2015 | 08:50 AM
jdblep's Avatar
jdblep
nope, end links are stock, and there doesnt appear to be anything obviously wrong (put the mini up on stands this weekend, pulled the front wheels, and rooted around to see if anything looked out of place).
Old Mar 23, 2015 | 08:57 AM
Mib4840's Avatar
Mib4840
Sounds like you probably pressure washed some grease out of something. Now that it's all clean you might be able to see what needs lubed.
Old Mar 24, 2015 | 11:58 PM
RHcoopers's Avatar
RHcoopers
Would you say the same for kyb, Sachs or lemfoerfer?
Old Mar 25, 2015 | 01:13 AM
Bearybee's Avatar
Bearybee
+1 on Lemfoder. I just replaced My struts on My R52 7k ago and have had no issues.
techgearpro
Jul 23, 2019 07:09 PM
embiggenedmini
Oct 15, 2015 12:36 PM
ptbster
Sep 13, 2015 07:22 AM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
