R50/53 R53 Bi-Xenon Journey
Old Feb 21, 2015 | 06:36 PM
jeffreybass0's Avatar
jeffreybass0
I have recently gotten a little into customizing headlights. Owning an R53, I got tired of the dull and murky projector lenses. So, I wanted to upgrade the lenses. Then I figured bi-xenon would be the best way to go. I feel as though bi-xenon projector lights are more efficient than any other form of lighting in cars (other than led's potentially). So anyways, I wanted to make my 2006 Mini's lights bi-xenon. Thus begins my journey:
I started out by taking the headlight apart (obviously). And if anyone is wondering how to take the headlight apart, there are many threads out there that you can find. After disassembling the headlight, I took out the projector assembily.
And here is the lens assembly I am replacing it with.
As you can probably tell it is comparatively crystal clear.
And here's what makes a bi-xenon light....bi.
Now the fun part is getting it to fit onto my oem reflector.
A little drilling was required to get it to work, but no big deal really!
Now here's a picture of what the final projector assembly looks like.
And my favorite part, the stock shrouding will fit after a grind a couple of grabby thingys. Wooohoooo, oem look is always best.
Unfortunately the solenoid is too boxy so I will have to grind into the bracket that holds everything.
Now all I have to do is a couple of things and they will be ready to go back into the headlight and hit the road. I will post more pictures as I go, now all I need is more time to work on them! Ahhhhh.
Old Feb 22, 2015 | 10:13 AM
markwerline's Avatar
markwerline
looks like Morimoto parts from The Retrofit Source?
looks pretty damn good too. I would be curious to see output shots when complete.
Old Feb 22, 2015 | 10:37 AM
jeffreybass0
Thanks Mark! They are actually some Morimoto knock offs that I ordered off of amazon. I put them in my girlfriends Toyota Corolla around Christmas time and I was impressed with the output so I ordered the same ones again.
Old Feb 22, 2015 | 07:01 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Nice write up !
Old Feb 22, 2015 | 07:48 PM
markwerline
Really? Can you post the link?
Old Feb 25, 2015 | 04:43 PM
AlexQS's Avatar
AlexQS
I was thinking the same thing.
I put Morimoto mini h1's in mine.
I'll give away this free idea: someone with a 3D printer, print up a bracket of some sort that will replace the halogen reflector in our factory headlight assembly, and be the perfect dimension to accept a Morimoto projector without all the grinding/dremel work.
Old Feb 27, 2015 | 09:20 AM
scoopy's Avatar
scoopy
do you have the light output. i put some s2000 projectors in mine before. but i sold the car and now i got a new one. i changd my bulbs to a cbi however, still lacking from my previous retrofit.
Old Feb 27, 2015 | 01:12 PM
markwerline
Yea, that plate would be handy! I have a full retrofit kit of Morimoto Mini H1's sitting around and I am buying my wife a R53... so needless to say she will be getting HIDs.
potterstein
Dec 30, 2024 05:18 PM
rtk90
Aug 29, 2019 09:08 AM
Gremothra
Sep 9, 2015 08:42 PM
Anakist
Australia
Sep 8, 2015 03:32 AM
potterstein
Sep 4, 2015 09:52 AM
