R50/53 No chrome tail lights
Looks clean , nice job. Doing this to the Euro OEM taillights would look great also.
Euro Taillights
https://www.northamericanmotoring.co...il-lights.html
Euro Taillights
Those euro tail lights look pretty cool.. might have to see about getting some of those later on down the line..
Very cool.
Those are the pre 7/2004 . not a direct swap for the 7/2004+ models , will have to do so wiring mod due to no reverse light.
@808Keith: Can you post a little more on the process, I assume you removed the taillights then split them? Are they pretty easy to split?
BTW: great looking Mini and light treatment. Nice work.
Inside the red lens will pop out but you gotta be a little careful as it's held in with 4 tabs. Use like wide flathead scewdriver or maybe like a stiff putty knife to help pry it out. It sounds like it breaks but that's just it releasing from the clips. Once it's out, I used rubbing alcohol to wipe off the chrome paint.
When putting everything back together it's jus the reverse.. pop in the red lens and make sure everything is clean.
On mine one of the lens I used 5-min JB weld and the other I used black silicone adhesive. Just wanted to see which was better.. So far both seem to work ok no difference except working times.. the JB is quick setting unless you use the regular JB weld and wait till everything has cured over night.
Sorry I didn't take any pics.. with a 1 year old I had a limited window in which to get this project done..
cm.d
Aug 19, 2015 08:51 AM
