Drivetrain Manic tune stage 2
Old Feb 4, 2015 | 10:36 PM
ukan16's Avatar
ukan16
Manic tune stage 2
Hi, just wanted to see who all is running a stage 2 manic tune and what mods you all had done prior to the tune. On mini dynamics website it states all of the "prerequisites" needed for the tune and I have all except for a catless dp. I have an akrapovic dp though and didn't know if that would be acceptable. Would love to hear what you all are running. Thanks!
Old Feb 4, 2015 | 11:04 PM
MarioKart's Avatar
MarioKart
Vendor
The Akrapovic DP will do fine and I would remove the 2nd cat. Doing a catless DP would yield more HP, cooler temps and deeper sound, but you are good.
Always use the highest octane possible and keeping your Minj serviced frequently. I encourage oil changes twice as often of what the dealer suggest.
You will love the tune.
mQubed Motorsport, Manic Tuning Dealer
Old Feb 5, 2015 | 03:33 AM
cerenkov's Avatar
cerenkov
I have the full Akrapovic exhaust including DP and I'm running the Stage 2+ Manic tune. Exhaust temps are ok mainly around 1250F-1350F with peaks less than 1450F during really hard driving.
Old Feb 5, 2015 | 05:53 AM
countrymanman's Avatar
countrymanman
I have the 2+ tune,with catless dp. I have all suggested parts plus forge recirculating valve. It's amazing, you'll love it. You should be fine with aftermarket dp, are you getting cel from it? Won't matter with tune,but just curious.
Old Feb 5, 2015 | 07:50 AM
ukan16's Avatar
ukan16
Thanks for all of the replies, guys.
The akrapovic was giving me a code but it's suppressed using a can tool.
Are you having good luck with the forge recirc valve and the tune playing nice together? I've heard mixed things/people having the forge BOV throw soft codes due to the valve staying closed. But they were all running stage 3. Just curious.
Old Feb 5, 2015 | 08:20 AM
countrymanman
I'm running the recirculation valve, not a bov. I haven't had any trouble with it at all. I like have a mechanical valve instead of the stock ecu controlled one. The ecu still thinks it's in control and hasn't thrown a tantrum yet.
Old Feb 5, 2015 | 11:12 AM
ukan16's Avatar
ukan16
Good to know, thanks for the info. I'd like to get one for the added boost it will be under and like the idea of the mechanical accusation, just wanted to make sure there weren't a ton of issues so far.
Old Feb 5, 2015 | 11:28 AM
countrymanman
The plug from the ecu into the one from forge doesn't fit quite right. Takes a little trimming.
Old Feb 5, 2015 | 11:31 AM
MarioKart's Avatar
MarioKart
Vendor
I agree with this. A small file will do the trick
Old Feb 5, 2015 | 11:43 AM
ukan16's Avatar
ukan16
Cool thanks.
Old Feb 6, 2015 | 03:54 PM
cambo's Avatar
cambo
I have an akra dp and had a stage 2 installed today. It's awesome man.
How do I put it...
Before, when pulling onto the hwy...I could always feel when I was around 65-70. The mini felt like it just didn't want to pull anymore...and I would know I was at about the right cruising speed.
Today...after the tune, I pulled onto the hwy, and that 'feeling' was not there in the slightest. I looked down and I was reaching 90--not exaggerating. D**n near pooped myself...again, not exaggerating...as I was in Virginia and VA State Troopers don't play.
Thank God there wasn't one around though...I would've been hosed for sure. And I would be holding big bubba's pocket tonight as I'm an unassuming Asian man that does NOT know karate.
Old Feb 8, 2015 | 08:07 AM
ukan16's Avatar
ukan16
Haha that's awesome. That "almost pooping myself" feeling is what I'm looking for.
What other mods are you running?
Old Feb 8, 2015 | 09:43 AM
cambo's Avatar
cambo
haha, don't get me wrong...the near accidental bowel movement was more from the thought of getting caught by a VA state trooper going that fast. (In case you don't know...reckless driving in VA is automatic jail time).
The mods I've got are a Forge IC, k&n intake, akrapovic dp, and the full oem turbo back Challenge mini exhaust. I also needed those colder spark plugs too, so I had those thrown in.
Old Feb 10, 2015 | 02:12 PM
molala's Avatar
molala
Dont you need upgraded FMIC for St 2? No?
Old Feb 10, 2015 | 03:04 PM
cambo's Avatar
cambo
Yes
Old Feb 27, 2015 | 09:44 AM
CMS3086's Avatar
CMS3086
Which Map you guys running on stage2.
Any one know the different between MapB and MapC ?
_____________
2012 CM S 2WD
+Manic Stage2 MapB
+Wagner IC\\Akrapovic DP\\BMC CAI\\Alta CRV\\JCW exhaust manifold\\IP coil\\Light pulley\\NM Torque Arm Insert
+NM Catback exhaust
+KW V3\\Eibach Control arm\\NM 22mm swaybar\\JCW front swaybar
+Alcon 6pot 355mm brake\\325mm rear brake disc
+Rays G25 Wheels
Old Feb 27, 2015 | 10:18 AM
molala's Avatar
molala
Didnt know they hv different maps or you mean files like stock, performance, race? Was looking into it for R60 and dont see it was mention they hv different maps. Maybe is for Cooper S/hardtops?
Old Feb 27, 2015 | 10:27 AM
CMS3086's Avatar
CMS3086
Each stage got 3 map for you to use SPS to change the best map match your hardware
Old Feb 27, 2015 | 10:29 AM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by CMS3086
Which Map you guys running on stage2. Any one know the different between MapB and MapC ? _____________ 2012 CM S 2WD +Manic Stage2 MapB +Wagner IC\\Akrapovic DP\\BMC CAI\\Alta CRV\\JCW exhaust manifold\\IP coil\\Light pulley\\NM Torque Arm Insert +NM Catback exhaust +KW V3\\Eibach Control arm\\NM 22mm swaybar\\JCW front swaybar +Alcon 6pot 355mm brake\\325mm rear brake disc +Rays G25 Wheels
Typically map A is 1.3bar, B is 1.4bar and C is 1.5 bar.
Old Feb 27, 2015 | 11:13 AM
CMS3086's Avatar
CMS3086
Today I upgraded my NM catback exhaust to quicksilver 2.5" exhaust system. Just thinking any improve if I change Map from B to C.
Now low rpm feel no good after upgrade the exhaust.
Old Feb 27, 2015 | 03:59 PM
mickeymo's Avatar
mickeymo
Has anyone with a tune replaced their clutch or is the stock one holding the power?
Old Feb 27, 2015 | 04:05 PM
molala's Avatar
molala
Always thought thr QS system is 3". How you liking it besides the low rpm and sound
Old Feb 27, 2015 | 04:47 PM
CMS3086's Avatar
CMS3086
sound are nice and loud after 3000rpm love it.
Just compare before and after QS seem oversize for stock S turbo.
Now my AT gearbox feel not that smooth than before....low rpm only noise
Old Feb 27, 2015 | 08:01 PM
molala's Avatar
molala
2.5" should be ok for the stock Krispy Kreme turbo. 3" forsure will kill it. I have NM and I really liked their quality and design of their products and i like the tips on the NM exhaust as it fill the JCW kit on the R60 nicely.
Strange is making the car not as smooth. I mean you are going up just 0.1" in piping from the NM. Give it a few days and drive around yr style and let the ECU learn it and see if it gets better
Old Feb 28, 2015 | 01:07 AM
CMS3086's Avatar
CMS3086
NM quality really better than QS. but the size different between it NM 2.36" catback connected to oem 2.17" center pipe and QS was 2.25" start from DP, so not just large 0.1"
I also think just little bit bigger size wont cause big problem before I buy QS.
