R52 Add-a-tap fuse location
Old Jan 25, 2015 | 07:09 AM
Goldsmithy's Avatar
Goldsmithy
MINI Alliance Ambassador
I just bought a 2005 R52 S and would like to add gauges. I don't want to cut into the original loom. I want to use add-a-taps for connecting to a power source, a switched power source, and an interior light source. I would really appreciate if someone could tell me which fuse position to use? Is there a better way than add-a-taps? I am going to install and oil pressure and a boost gauge. As always, TIA for any help I can get.
Old Jan 25, 2015 | 08:09 AM
ZippyNH's Avatar
ZippyNH
Suggest you get a voltmeter...then open the fuse panel by the drivers side leg area ..
And just find which ones are hot, and which are switch, then use the add a fuse/fuse tap...the make sure it is on the unprotected side, add an inline fuse....and you can use any one that suits you needs...I suggest always using a switched on....and there are a few good bolts to use as grounds in the area if you look around.
Don't really have a specific fuse #, cause you will find mini's were EVOLUTIONARY in their production...with many changes rolled out based upon the production date, not model year...so the fuses changed several times for some items.
Old Jan 25, 2015 | 08:16 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Use the Cig. Lighter fuse and you should be fine.
lweaver
Sep 17, 2024 08:22 AM
Filmy
15
Jun 6, 2023 06:27 AM
eliseo1981
Sep 30, 2015 01:53 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
