R50/53 General consensus on pully sizes
Old Jan 24, 2015 | 07:12 PM
'10JCW's Avatar
'10JCW
So I have done some research and I have come to the conclusion that:
15% is less power but less temps
17% more power and really only recommended with a GP intercooler, it also has a greater chance of damaging the engine/supercharger
What about the 16%? There are limited options, but is the 16% w good option, epecially if other mods and a tune are planned? Thanks
Old Jan 25, 2015 | 08:39 AM
fastzombie's Avatar
fastzombie
I have an R53 with a 15% and it now has 140,000 miles on it. It runs very good and doesn't appear to have caused any issues.
Old Jan 25, 2015 | 09:22 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We offer all three sizes and anymore it's hard to say what is the most common as years ago it was always the 15%. Now with more people realizing they aren't going to ever track their car we see more go with the 16% and 17%.
I personally have a 15% pulley on my car. But really it's up to you. The smaller pulley will give you a little more grunt on the low end than the 15% but will be less efficient at the higher RPM.
Either way they will both give you more power and a huge grin
Old Jan 25, 2015 | 09:30 AM
fastzombie's Avatar
fastzombie
Just to add, I have the 15%, Cold Air Intake and a Stratmosphere Exhaust and absolutely love the car's performance. Torque and power with reliability.
Old Jan 25, 2015 | 01:09 PM
miniblucabrio's Avatar
miniblucabrio
Really the only difference between the three is the torque curve. The 17% will bring on the torque a little earlier than the 15%. Because it's only a couple psi difference between them you won't notice a big gain in power from one to the other. I went with the 17% because I knew I wouldn't be tracking the car at all. I do run it up to redline regularily and have had no issues.
Old Jan 26, 2015 | 05:33 AM
Saltysalt's Avatar
Saltysalt
there is also a 19%, I would only recommend that if you have an electric water pump. 17% is used a lot when you know you wont be hanging around at redline like at a track. 15% is most common
Old Jan 26, 2015 | 06:05 AM
ZippyNH's Avatar
ZippyNH
I have a 17%...perfect for a commuter...like said before, brings the boost on at lower rpms.
My suggestion...
If you are a track/redline junkie, and spend lots of timing running redline, get the 15%...
If you drive your car semi normal and floor it sometimes on ramps, etc, get the 17%, especially if you can get 93 octane...
If you are indecisive about everything, and wear one black sock and one brown sock just to be sure you are prepared, get the 16%!! Just kidding there....
Old Jan 26, 2015 | 07:07 AM
Saltysalt's Avatar
Saltysalt
and if you do track time, get a water/meth injection kit, negates all the heat created from the 17%
Old Jan 26, 2015 | 07:58 AM
'10JCW's Avatar
'10JCW
Think I am going to do the 16% and add meth/water later.
Old Jan 26, 2015 | 06:22 PM
IQRaceworks's Avatar
IQRaceworks
Unless you are going to be on a track and/or holding your RPM's up high for long periods of time....go with a 17% pulley. The boost will come in a little faster at lower rpms compared to the 15%....I think that's worth it Lots of people run 17% pulleys on a stock motor without any issues at all.
Doc Pain
Oct 28, 2015 07:09 PM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
WhinyR53
Sep 30, 2015 07:36 AM
BossyR56
Sep 28, 2015 11:33 AM
gnhovis
Sep 28, 2015 06:28 AM
