What is the Recommended Torque on the Lug Bolts?
Old Jan 16, 2015 | 09:53 AM
14R55S's Avatar
14R55S
New wheels going on next week and I would like the shop to know that.
Old Jan 16, 2015 | 10:31 AM
14R55S's Avatar
14R55S
Service Advisor at MINI says 90lbs. Sounds right to me.
Old Jan 16, 2015 | 10:32 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.northamericanmotoring.co...ut-torque.html
Old Jan 16, 2015 | 11:01 AM
14R55S's Avatar
14R55S
Read that thread. Lot's of disagreement. It turned into more of a discussion about torque wrenches. Wasn't really helpful.
Old Jan 16, 2015 | 11:25 AM
ra2fanatic's Avatar
ra2fanatic
+1
I do it to 90lbs as well.
Old Jan 16, 2015 | 11:53 AM
rwkeating's Avatar
rwkeating
Mid 2006 they changed to a larger lug bolt. The Bentley service manual list the spec for the smaller bolt as
120 Nm (+-10), 89 ftlb (+-7)
So on your 2014, it should be higher than that.
Old Jan 16, 2015 | 03:08 PM
hsautocrosser's Avatar
hsautocrosser
103.3 lb ft for my 2010 hardtop and 2014 Roadster S per the manuals.
Old Jan 16, 2015 | 03:27 PM
14R55S's Avatar
14R55S
What manual are you going by? Owners manual or shop manual?
Old Jan 16, 2015 | 04:34 PM
cerenkov's Avatar
cerenkov
Page 229 of the 2013 R56 Manual (I'd imagine the R55 would be the same):
Tightening the lug bolts
Tighten the lug bolts in a diagonal pattern.
Immediately have the wheels checked
with a calibrated torque wrench to ensure
that the lug bolts are firmly seated. Otherwise,
incorrectly tightened lug bolts can present a
safety hazard.
Tightening torque: 103.3 lb ft or 140 Nm.
Replace the defective tire as soon as possible
and have the new wheel/tire assembly balanced.
Old Jan 16, 2015 | 05:06 PM
Minnie.the.Moocher
It is in the owners manual, not sure why this is such a hotly debated topic all the time.
Old Jan 16, 2015 | 05:25 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I do 90 ft lbs and it works fine
Old Jan 17, 2015 | 03:45 PM
MrElusive's Avatar
MrElusive
Look at your owners manual. Different specs for different vehicles. For my 2015 R57 manual, it says 103.3 lb ft.
If you need quick access to the manual, go to miniusa.com and pull the owners manual under the OWNERS section of the site.
Old Jan 26, 2015 | 08:36 PM
Btwyx's Avatar
Btwyx
Should be 140Nm, which is the 103.3 quoted.
Old Feb 8, 2015 | 04:13 PM
mbwicz's Avatar
mbwicz
Remember that the 140 nm (103 ft lb) is a dry torque. I put a couple of drops of motor oil on my bolts and torque to 90 ft lb. If you reduce the friction by lubricating the threads (or tapered surface) then you must reduce the torque value.
Mike
USA-RET
Nov 9, 2015 07:27 PM
Sep 4, 2015 09:23 AM
Sep 3, 2015 10:29 AM
Sep 2, 2015 11:15 AM
cw40342
Sep 2, 2015 06:01 AM
