Just got my Mini to the dealership......it isn't good
Old Jan 7, 2015 | 11:38 AM
'10JCW's Avatar
'10JCW
So I have a laundry list of repairs:
Timing chain tensioner - standard, may good faith it
Thermostat housing - gonna repair it using the Bently manual
Brakes - putting them on soon, is there any problem with reusing the rotors if they aren't warped?
Electrical issues - so the following items don't work: windows, high beams, rear light, and blinkers. Dealership said it was an electrical modular on the drivers side? Is this an easy job for a DIYer? Also, they said it has to be reprogrammed at the dealership, is there any truth to this? Right now, I am at a $4000 bill and need to bring that down a bit. Thanks in advance for the help.
Old Jan 7, 2015 | 01:27 PM
JAB 67's Avatar
JAB 67
$4000? And you're not upset? What year and how many miles?
Old Jan 7, 2015 | 02:05 PM
"So I have a laundry list of repairs:
Thermostat housing - gonna repair it using the Bentley manual
Electrical issues - so the following items don't work: windows, high beams, rear light, and blinkers. Dealership said it was an electrical modular on the drivers side? Is this an easy job for a DIYer? Also, they said it has to be reprogrammed at the dealership, is there any truth to this? Right now, I am at a $4000 bill and need to bring that down a bit. Thanks in advance for the help."
1. Timing chain, if they don;t good will it :
http://www.ecstuning.com/Mini-2010-Cooper-R56-John_Cooper_Works-Coupe-L4_1.6L_N14B16C/Engine/Timing/
2. Thermostat housing here DIY
https://www.northamericanmotoring.co...hermostat.html
In addition.
6/2010-3/2012 for JCW models need the pigtail wire. 12517646145
3. Brakes : Measure the thickness and the min thickness is maked on the side of the rotor on the stock rotors. If below replace:
http://www.ecstuning.com/Mini-2010-Cooper-R56-John_Cooper_Works-Coupe-L4_1.6L_N14B16C/Braking/Service_Kits/
4. Footwell module, have that check for corrosion from the water.
5. Bentley Manual , A must for the DIY 'r , great price and free ship.
http://www.ecstuning.com/News/R55_R56_R57_MINI_BentleyServiceManual_2007_2008_20 09_2010_2011_2012_2013/
Thanks and should help you same some $.
Old Jan 7, 2015 | 02:12 PM
'10JCW's Avatar
'10JCW
In addition.
Yea thanks. I have the Bently Manual and it is worth its weight in gold. As far as the module, where should I have it tested? The dealership said it was bad but said the area was completely dry (my car has never been rained in). Like I said, It worked fine even yesterday, but I left my car out in the cold last night (instead of the garage). When I started my vehicle, it was very slow to turn and eventually started, but that is when I noticed the issue. At first, I thought was like a daed battery reset, but that didn't work. Thanks so much for the links and response, I will definitely be buying at ECS vs the stealership.
Old Jan 7, 2015 | 02:19 PM
Check the battery and the alternator, make sure they are fine, low drain on the voltage causes all kind of problems.
The footwell module check the pins connection for moisture, then open it up and have a look inside. If bad and still have to replace then I can get you the part number ~ $330.00 for a new one.
You are welcome.
Old Jan 7, 2015 | 02:23 PM
xsmini's Avatar
xsmini
Looks like you may owe ECSTuning a few grand for all of the money they just saved you. Or at least a cold beverage.
Nik
Old Jan 7, 2015 | 02:24 PM
I will take a virtual soda. ::
Old Jan 12, 2015 | 05:21 AM
mini4mo's Avatar
mini4mo
The dealership just replaced the footwell module in our '12 MCS.
It was causing the interior lights not to work and killed a cell in the battery.
09R56
Nov 16, 2022 10:49 AM
MiniJess
Aug 10, 2015 09:51 PM
bc219
Aug 10, 2015 11:22 AM
jrezzo
Aug 9, 2015 10:32 PM
O4mcs
Aug 6, 2015 05:42 AM
