R50/53 Aftermarket Shift Knob Options?
Aftermarket Shift **** Options?
So i have been looking through NAM and the interwebs and i seems that the only Mini Specific aftermarket **** is from Whalen Shift Machine. Are they any others. i am only interested in a **** made for the mini cooper not a universal or one that requires an adapter. if it makes a difference i have an 02 R50
Raceseng has some nice ***** - including some delrin-wrapped ones about
1# in weight like their Topologi - for those who don't want to grab a metal
**** in the dead of winter or the heat of summer. Pricey like the Whalens,
but they look appealing.
http://www.raceseng.com/topologi-shi...6-speed-manual
http://www.raceseng.com/auto/mini/shift-*****
yeah im definitely going with the ashiko unless i find something heavier. id rather spend $150 and change shift feel then spend $25 and make it pretty. luckily that ashiko will be both
A heavier shift **** gives more momentum/inertia when shifting, which helps on the
relatively high-effort nature of the Getrag and its associated shifting mechanism,
especially when engaging reverse.
... up to a point. If you attach a 16# bowling ball, it's gonna make it worse, not better.
I would guess that about 16-24 oz (1 - 1.5# or 455 - 682g) - would be the sweet spot
in terms of weight range for a shift ****.
That might hold true if you are slamming through the gears in a race car, but on a daily driver...I doubt anyone would ever notice. Not much inertia force generated with slow easy shifts.
The Whalen **** is a fantastic piece, from the weight to the custom engraving, everything about the **** is great, but the price is steep.
I have a Craven Speed **** on my car, which they have as of recent stopped manufacturing due to cost. It weighs a little less than the Whalen ****, but is also half the cost.
We have one left in stock, $99 plus shipping.
Let's say it takes you 1/2 second to make a shift.....moving your shifter **** 4 inches. That means you are moving your shifter ball 8 inches per second.
If the shifter **** weights 16oz (1lb or .4535kg)..and it's moving at 8in/sec....that's equal to .2032 meters/second.
When you do the math...the momentum change is 0.09 kg-m/s. So.. that means that .09kg (3.17oz) of force for every meter per second.....so .2032.
So...3.17oz x .2032 = .64 ounces........that is how much extra momentum a 16oz shifter **** generates when you move it 4 inches in 1/2 a second. That's .04 lbs. What's a stock know weight? 1/4lb? OK...so you changed the momentum by .01lbs ....that's nothing.
I'm not 100% sure the math is right...but I think it's pretty close
