Mini coolant
Old Dec 16, 2014 | 05:29 PM
Convincor's Avatar
Convincor
Mini coolant
Recently bought my first Mini, 2007 base. I have put 150 miles on it and it now needs a water pump at 53k miles. The coolant that is leaking out is green. From what I have read Mini coolant should be blue? Does it matter if I add green back in after the water pump install or should I try to drain all out and put in Mini coolant?
Old Dec 16, 2014 | 06:03 PM
danjreed's Avatar
danjreed
Correct the factory coolant is G48 spec (Blue). Its a BMW coolant, also used by many other brands.
If you have green in there, as long as all the old stuff was flushed out, green generic coolant will be ok.
Old Dec 16, 2014 | 07:01 PM
Convincor's Avatar
Convincor
Thanks! That's the response I was looking for.
Old Dec 16, 2014 | 08:05 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the MINI factory coolant is a blue color. Using the Green is fine and won't hurt anything. The problem will come in if you use Dex cool with regular coolant as it turns to jello.
Old Dec 16, 2014 | 08:29 PM
Convincor's Avatar
Convincor
So how do you determine what is in it now? Is Dex-cool green?
Old Dec 17, 2014 | 06:31 AM
scott13's Avatar
scott13
Dexcool is orange-red in color
Old Dec 17, 2014 | 07:01 AM
Convincor's Avatar
Convincor
Thanks for the info.
Old Dec 17, 2014 | 12:22 PM
kyoo's Avatar
kyoo
lol the one i started using in my evo is RED, pretty weird for me
Cereall
Sep 5, 2019 06:05 PM
theateist
Jul 2, 2017 02:21 PM
KrisMiss
Jan 3, 2016 02:02 PM
Gipper
Aug 8, 2015 05:39 AM
kwijmbo
Aug 5, 2015 09:00 PM
