R50/53 Question about swapping to leather heated seats
Old Nov 5, 2014 | 02:45 PM
BoostedBlueToyotas's Avatar
BoostedBlueToyotas
I managed to buy a second 2006 JCW. It didnt come with leather, cold weather package, or HK audio. My first JCW did. I am looking to swap
in some stock leather seats (it had aftermarket leather seats installed at Dealer) with heat. Prefer the English panther leather seats that
my first car has. Second car does not have an extra plug so its not
prewired for heated seats :(. Is there a good place to pick up seats. Dont
see any advertised here or on the web in general.
Old Nov 5, 2014 | 03:12 PM
ZippyNH's Avatar
ZippyNH
What year was the first car you are pulling the seats out of? If you BUY them...make sure they are from PRODUCTION DATE 2005+ (my 2004 build, but 2005 model car does not have the sensors)...the sensor is in the bottom cushion...about a $1000 item if it fails...
I ask because 2005+ PRODUCTION date cars have an extra weigh sensor in the passenger seat because they have duel stage Airbags that varry based on the passenger weight...older cars had only single stage....
Old Nov 5, 2014 | 04:12 PM
BoostedBlueToyotas
I need to find the seats (hard part) from somewhere. Will do on the production date. I figure getting this done is a long shot. I assume that I will have to contact a recycling/wrecker yard via the internet to find the seats. Car was originally from Florida so can see why they didnt get the package. The seats in the car are very nice, 2 tone black/grey with JCW emblems on the headrest but really want heat
Old Nov 6, 2014 | 01:15 PM
Are the seats themselves prewired for heat that you are putting in ? If so you can always add the heated seat switch side.
https://www.northamericanmotoring.co...ted-seats.html
Double check on the production you will need the newer 2005 seats, I have an early 05 right before the seat sensor came active.
Old Nov 6, 2014 | 04:49 PM
BoostedBlueToyotas
They are not prewired :(. They were the base plastic surface seats. Dont have a problem with the existing leather so maybe retrofitting them is a better option? Wouldnt mind having heated mirror either.
Production date is March 18, 2006 according to BMW VIN decoder
Old Nov 7, 2014 | 04:59 AM
I have seen the non sport seats leatherette ( thats what they are called ) version pre wired ? I would double check. Good luck.
Old Nov 8, 2014 | 11:44 AM
FredoinSF's Avatar
FredoinSF
How does one find out for sure? Did not order heated seats because I was trying to stay below a certain price when I bought the car, it's really the only equipment I wish I could retrofit.
Old Nov 8, 2014 | 12:41 PM
ZippyNH's Avatar
ZippyNH
It seems about 50% of cars got the heated seats...just not hooked up...
Seems mini over ordered... And they were installed in many cars, but not plugged in!!
Look under the seat for an unused connector...
If you see an empty plug...you should be in luck!! A few older threads on it...I was not lucky... But many were...and only needed the retrofit kit..
Old Nov 8, 2014 | 03:03 PM
FredoinSF's Avatar
FredoinSF
^^^^ Thanks Zippy! Will investigate tomorrow.
Old Nov 8, 2014 | 09:49 PM
bjcarter2's Avatar
bjcarter2
Weird - My '06 R53/JCW came leatherette seats with a wired drivers seat but not passenger. I am going to install a switch and harness and run it though. Nothing like a toasty tush.
Old Nov 9, 2014 | 01:27 PM
BoostedBlueToyotas
I am definitely confused. When I shopped for my first Cooper I looked at a Royal Grey JCW with english panther leather but no cold weather package that was prewired (it had a spare big black plug). My JCW with same seats and cold weather looks the same, the drivers side has 4 plugs, blue, yellow, small black, large black [heated seats]. My silver JCW with no cold weather has only the blue and black plugs, no small or large black plub) on the drivers seat. The passenger seats has 4 plugs, blue, yellow, small black, and a white/black combo. ?????
Old Nov 9, 2014 | 02:09 PM
ZippyNH's Avatar
ZippyNH
The extra plug on the passenger seat if for the seat mat, aka, the weight sensor ..
If all the plugs are used...no luck.
It was speculated that mini did not order enough unheated seats...so they just grabbed the heated, and left them unplugged and unwired if the car did not need heated seats...
Most cars have had at least ONE person look under the seat by now...but a few are likely undiscovered still....
Old Nov 10, 2014 | 06:46 AM
Think it was a supplier shortage too zippy. Check under the seats, linked above.
FrostyFox
Oct 28, 2015 02:06 PM
bseiden
Aug 15, 2015 10:16 AM
ludedude
Aug 10, 2015 07:16 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
marendt428
Aug 8, 2015 04:44 AM
