FS:: R56 Alta/Jcw/Oem/Autopower/Blast Parts for Sale
Old Oct 26, 2014 | 10:58 AM
knuckleheadbob's Avatar
knuckleheadbob
Price: $0
Location (Region): Midwestern
I have some performance parts for sale, no pictures but i can add them if needed. from my 2008 MCS hardtop
1. Alta AccessPort unmarried in original box with all cables 550.00
2. Alta 3" stainless exhaust downpipe back with vbands *** SOLD ***
3. ATP 3" catless downpipe wrapped with vbands *** SOLD ***
have a custom stainless flange that i will throw in to mate the atp
downpipe with the alta exhaust
4. New Stage 2 K04 turbo 750.00
TURBINE SIDE: K04... 44.5 X 50mm Turbine wheel
CENTER SECTION: VSR balanced. OEM housing, bolt-on.
COMPRESSOR SIDE: 45.1mm X 59 mm compressor wheel
360 thrust bearing
VSR balanced & tested
5. external audi diverter valve and relocation 100.00
6. updated factory exhaust manifold 100.00
7. new oil pan with temp sender bung welded in 125.00
8. OEM Tach 35.00
9. OEM A pillar trim Black 35.00
10. OEM steering column trim Black 35.00
11. couple of OEM shifter ***** 6 speed 5.00 ea
12. full set of team dynamics 1.2 17x7.5 with pirelli pzero 215/45ZR17
with TPS sensors 1000.00 wheels and tires are in excellent condition
no scuffs no rash, tires are like new
13. Autopower 4point roll bar 350.00
shipping will be whatever the actual charges are.
Old Oct 26, 2014 | 04:37 PM
12coopers's Avatar
12coopers
I am interested in your exhauset and DP. Any thoughts on what the shipping might be to 33470?
Old Oct 27, 2014 | 12:04 PM
catASTROphicR56's Avatar
catASTROphicR56
Will the ATP downpipe fit stock exhaust and turbo?
Old Oct 27, 2014 | 02:23 PM
knuckleheadbob
Shipping
Exhaust and DP are roughly about 65lbs boxed, best guess can ship with any carrier fedex or ups are better choices for the weight
Old Oct 27, 2014 | 02:27 PM
knuckleheadbob
Fit
the downpipe will fit stock turbo, recommend to remove the studs and switch to bolts. the nut closest to the manifold is a pain to tighten down if you stick with the studs. will not work with the stock exhaust, downpipe is 3"
Old Oct 29, 2014 | 08:45 PM
Indimanic's Avatar
Indimanic
did u sell the dp? Need to make a move tomorrow.
Old Oct 30, 2014 | 02:43 AM
mini_aaron's Avatar
mini_aaron
So is the K04 used or really brand new?(as it states it's new)
Could you send some hi-res pictures to : ontrack24 at gmail dot com?
Old Oct 30, 2014 | 03:44 AM
knuckleheadbob
DP and exhaust are sold
Old Oct 30, 2014 | 03:45 AM
knuckleheadbob
yes the K04 is new and in unused condition. built by blast performance
Old Oct 30, 2014 | 05:52 AM
mini_aaron's Avatar
mini_aaron
Good to hear that. Interested. Will be waiting for the pics! :D
marendt428
Nov 14, 2015 10:03 AM
wkp1219
Nov 13, 2015 07:52 AM
Emnotek
Aug 13, 2015 05:47 PM
marendt428
Aug 8, 2015 04:44 AM
