R50/53 Is this a good place to buy from?
Old Oct 24, 2014 | 03:11 PM
Twisted Polak's Avatar
Twisted Polak
im about to buy these items and I was wondering if its a good idea?
or maybe I should go somewhere else to get these parts.
also interested in buying the thermostat and housing at the same time.
http://www.ebay.com/itm/360962063136
Old Oct 24, 2014 | 03:42 PM
RDY4TKF's Avatar
RDY4TKF
Amazon is cheaper
Old Oct 24, 2014 | 03:46 PM
Twisted Polak
Originally Posted by RDY4TKF
Amazon is cheaper
cant seem to find a set like this any cheaper.
Old Oct 24, 2014 | 04:48 PM
bavmotors's Avatar
bavmotors
Originally Posted by Twisted Polak
im about to buy these items and I was wondering if its a good idea? or maybe I should go somewhere else to get these parts. also interested in buying the thermostat and housing at the same time. http://www.ebay.com/itm/360962063136
Id just get the gates on rock auto
Old Oct 24, 2014 | 04:55 PM
Twisted Polak
could you elaborate a little more on that? I just got my mini a week ago and in not entirely sure what that is.
Old Oct 24, 2014 | 05:33 PM
Fizzyx's Avatar
Fizzyx
http://www.rockauto.com/
http://www.rockauto.com/catalog/more...909&cc=1432681
5% Discount Code: 2D09DA1EC3A88E
Expires: 11/04/2014
Old Oct 24, 2014 | 05:43 PM
Twisted Polak
any reason to get that one instead of the OEM one? I will also be replacing it with the Alta tensioner stop...... not sure if that a good idea yet.
Old Oct 24, 2014 | 06:03 PM
bavmotors's Avatar
bavmotors
Gates is oem.
Old Oct 24, 2014 | 09:19 PM
elchilo4ever's Avatar
elchilo4ever
I Have This One.
Adjustable Alta Tensioner.
N' Is Working Really Good!
http://altaperformance.com/i-1400712...ed-engine.html
Old Oct 29, 2014 | 01:50 PM
Twisted Polak
Originally Posted by elchilo4ever
I Have This One.
I really like that one too.....how often do you have to adjust it????
Old Oct 29, 2014 | 01:57 PM
Twisted Polak
I also found out that the one on Ebay is from a company called LUK...... I don't know anything about them.... they said that they are oem manufacturer for mini.
Old Oct 29, 2014 | 02:03 PM
bavmotors's Avatar
bavmotors
luk is good too, I would stay away from the adjustable. Get the OEM style, it changes tension constantly, replace it and forget about it.
Old Oct 29, 2014 | 02:04 PM
elchilo4ever
Well I Installed......
Take Them For Ride N' Need
More To Get Adjust N' After That Is
All Ok.
Also Really Easy To Install.
I Really Recommend!
Old Oct 29, 2014 | 02:05 PM
Twisted Polak
luck is good too, I would stay away from the adjustable. Get the OEM style, it changes tension constantly, replace it and forget about it.
thank you for the advice..... what about this part for the tensioner? is this a good idea?
Old Oct 29, 2014 | 02:11 PM
elchilo4ever
Well I have That One Before N' Work Fine. But Everybody Say After Couple Months That Piece Raffle.....
Old Oct 29, 2014 | 02:28 PM
bavmotors's Avatar
bavmotors
thank you for the advice..... what about this part for the tensioner? is this a good idea? http://altaperformance.com/i-1400712...ed-engine.html
I have it and mine rattles at low rpm, I'd get the wmw stop. The only advantage to the alta is it can be installed without removing the tensioner assembly.
Old Oct 29, 2014 | 03:22 PM
ZippyNH's Avatar
ZippyNH
+1
LUK is one of the clutch/dual mass flywheel suppliers....
Most every item on the car has 2 different suppliers....
But one tip...
Many OEM makers have 2 lines of parts....
An cheap Chinese made one...some of the "gates" water pumps that pop up cheap, than leak are these, and the real OEM parts....
The tensioner from gates has been widely used and is good...
The Alta fixed tensioner WILL COST YOU HP....no one belt pressure is good for all rpms and loads..... Period.
And a few picture are around of failures of the fixed tensioner...vibration and pressure overtime can snap them....do not consider it a permant, one time fix...
Just like a heavy duty truck with the same style of tensioner, expect to readjust the tension every few thousand miles....least it squeel or snap the belt...
Old Oct 29, 2014 | 03:24 PM
ZippyNH's Avatar
ZippyNH
A tensioner stop IMO is a good idea...
Some rattle....
Some do wear and fail from age (strap style)...none are perfect...but spending 20-30$ to maybe save $500+ IMO is s good risk.
Old Oct 29, 2014 | 07:56 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Be careful I've had customers buy the cheaper versions of these parts only to have to replace them again. So if they don't warranty it, you end up spending what the OE would have cost.
As for the Alta tensioner stop don't bother as it doesn't allow the tensioner to adjust belt tension with load change so the belt is going to be either to tight or too loose depending on the load you have on the car.
We make our own delrin bushings to replace the stock rubber bushings on the tensioner shock as that is what actually fails on the tensioner.
http://www.waymotorworks.com/wmw-sup...shing-set.html
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
caiken
Aug 27, 2015 06:55 AM
JPMM
Aug 13, 2015 12:01 PM
minipopkart
Aug 13, 2015 05:22 AM
xpunisherx
Aug 10, 2015 10:50 PM
