HPFP- early failure warning signs?
Old Oct 13, 2014 | 09:12 PM
kj6epl's Avatar
kj6epl
I see lots of posts about failed HPFPs in R56s. Particularly alarming to me is that it seems it can fail without warning, causing the car to die suddenly or go into limp mode. Looking at this from a proactive standpoint, is there anything that can be done to check the condition of the HPFP prior to a "sudden" failure? Fuel rail pressure is a PID accessible with any generic OBD scan tool; would certain pressure ranges designate a healthy vs dying HPFP? Any other early failure warning symptoms?
Old Oct 21, 2014 | 05:32 AM
Big Jim Swade's Avatar
Big Jim Swade
I don't think there are any warning signs until it actually fails. One thing you can do to prevent failure, is to stay away from fuel with ethanol in it. I'm still on my original pump, but I've only used fuel with ethanol 2 times since I've owned the car. And that is only because I was in an are where there was nothing else.
Old Oct 21, 2014 | 05:46 AM
MikewithaMini's Avatar
MikewithaMini
I discovered mine was about to fail when I turned off the auto AC one first nice day and the car stumbled all over the place at idle. With the AC on, the idle level was boosted enough to mask the issue.
randeez
Oct 5, 2015 09:23 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
