R50/53 Can I buy this part?
Old Oct 12, 2014 | 03:42 PM
agood1's Avatar
agood1
From inside the oil filter housing.
It appears 2 of the 3 clips are broken.....It will stay in the housing....but Im getting a low pressure light....so I hope this is the problem
Old Oct 12, 2014 | 03:55 PM
MINIAC's Avatar
MINIAC
RealOEM - BMW Online Parts Catalog
Old Oct 12, 2014 | 05:05 PM
Eric_Rowland's Avatar
Eric_Rowland
AFAIK, the answer is no. But I've seen a post from an intrepid MINI guy who used a circlip on the backside of the valve to hold it in place.
Old Oct 12, 2014 | 06:48 PM
agood1's Avatar
agood1
Could this plastic piece just be a drain back valve that opens when you take out the oil filter so the residual oil will drain back into the oil pan? It looks like that is all it is....so blocking it off with a rubber stopper should solve the low pressure problem with only an spillage issue when you do and filter change.
Does this seem logical?
Old Oct 12, 2014 | 07:21 PM
MVPeters's Avatar
MVPeters
See this thread, I think it's the same thing.
https://www.northamericanmotoring.co...er-beware.html
Mike
Old Oct 12, 2014 | 07:28 PM
agood1's Avatar
agood1
Thanks, Already read that thread cover to cover....I even posted on it today.....but most of the posts are old, and hoping someone has come up with a solution since.
Old Oct 13, 2014 | 05:10 AM
JABowders's Avatar
JABowders
Veteran: Army
Looks like it would coma as part of the "OIL FILTER WITH ALUMINIUM COVER" basically having to replace the entire Oil Filter Housing.
Alternate: Maybe it can be found on a engine being parted out from a salvage yard/shop.
Motor on!
blackie
Oct 2, 2015 07:41 PM
xraycat
Aug 15, 2015 06:43 AM
messyjesse96
Aug 12, 2015 05:51 AM
nomar116
Aug 10, 2015 11:24 PM
