R50 coolant leak
Old Oct 8, 2014 | 11:19 AM
schererpr's Avatar
schererpr
R50 coolant leak
Replaced the 3 radiator hoses on my mini and followed the process to refill and bleed (including overflow tank), but now have leak from driver's side of engine when running. Removed battery box for visibility, attached a pressure tester & pumped up to rated psi. Can't see anything leaking, or even dripping under car, but pressure gauge bleeds down in ~ 10 seconds. Any ideas?
Old Oct 8, 2014 | 01:12 PM
cristo's Avatar
cristo
Alliance Member
Thermostat gasket is the #1 suspect. Thermostat housing or coolant temp sensor
less likely but possible.
Old Oct 8, 2014 | 07:32 PM
goin440's Avatar
goin440
If you see coolant on top of the transmission, its the thermostat gasket. Replace w new thermostat and new gasket. I recall being able to get separately but you want them both.
Leak down gauge? Having never used a leak down for a coolant issue, without a drip anywhere and the age of the R50, if its not leaking on the outside, then... inside
Old Oct 16, 2014 | 08:59 AM
schererpr's Avatar
schererpr
Mini coolant leak
It was the coolant temperature sensor. The plastic part that the harness plugs into had lost it's seal to the brass part although still attached. Replaced the thermostat & seal also while I had the battery box & air box out.
Old Nov 21, 2014 | 08:37 PM
HyTech's Avatar
HyTech
From: Part year in Portland OR, part year Kalamazoo MI
I once had a leak in the hose to the coolant tank. Pressure tester wouldn't find that.
Old Dec 13, 2014 | 07:35 PM
1ofoneR52's Avatar
1ofoneR52
Check the radiator hose or any hose that runs coolat to the engine
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 3, 2015 12:24 PM
Sep 2, 2015 09:05 AM
