misfire codes after parked for a few days.
Old Oct 8, 2014 | 05:10 AM
madmaxxed's Avatar
madmaxxed
I had my car parked since Saturday evening and figured i'd take it to work today. It's been a bit on the damp side here in NH. I started the car, it seemed to sputter a bit and have an abnormal idle. I ran both GoPoint software and Dash Command to read 3 misfire codes. This is the second time it's happened to me in the last several months. I blamed the first on from cheap fuel. The car didn't seem to run any different than normal. I cleared the codes, restarted the car, ran both apps and found no codes. This is a 2010 MCS with almost 30K. Thoughts? Just a fluke?
Old Oct 9, 2014 | 07:59 PM
Systemlord's Avatar
Systemlord
I take it the idles was erratic, could be the HPFP. Sounds like a fuel or coil problem.
Old Oct 10, 2014 | 03:45 AM
madmaxxed's Avatar
madmaxxed
The idle wasn't bad really. It almost huffed and puffed at first start which triggered me to scan. It ran fine too. I pulled the coils and blasted them with a shot of air in case there was any moisture in and around the plugs.
Sent from my iPad using NAMotoring
Old Oct 10, 2014 | 09:01 PM
Systemlord's Avatar
Systemlord
Well this is for sure, something is going to fail eventually. It could be anything, how long does this huff and puff last? I had a lean condition a year ago with 100% power loss at 65 MPH and never received any codes. Sorry I can't be of more help to you, it's tough to diagnose a problem when they don't happen often. I'm sure it's probably something small like a sensor.
Old Oct 12, 2014 | 12:11 PM
madmaxxed's Avatar
madmaxxed
The noticeable difference in idle only lasted for a minute or so. The exact same thing happened twice now.
Old Oct 12, 2014 | 01:04 PM
Systemlord's Avatar
Systemlord
A minute is a long time, the ECU should have given a code after that amount of time. Whatever is happening seems to be getting progressively worse as time goes on, I'd call that a good thing because then you can diagnose it easier.
Old Oct 12, 2014 | 01:13 PM
jcauseyfd's Avatar
jcauseyfd
Sounds like HPFP to me.
xpunisherx
Nov 27, 2015 03:32 PM
embiggenedmini
Oct 15, 2015 12:36 PM
Filmy
Sep 7, 2015 08:27 PM
MasterShaftner
Sep 4, 2015 03:52 PM
SneedSpeed
Sep 2, 2015 05:34 AM
