R52 Engine Cooling Thoughts
Old Sep 17, 2014 | 06:40 AM
Bombadier36's Avatar
Bombadier36
I have a 2007 JCW convertible and the engine runs warmer than I would like. The car has a cold air intake, upgraded supercharger, upgraded fuel injectors, and some other non-engine upgrades (suspension, brakes, etc.). I do not drive it hard but it is my daily driver.
After a 20 minute drive the engine is hitting a bare bit about halfway on the temperature gage. I am looking for some upgrades (cheap if possible) to help the engine cool better.
Old Sep 17, 2014 | 06:53 AM
Bombadier36
I did forget to add that the exhaust has also been upgraded.
Old Sep 17, 2014 | 09:02 AM
buzzsaw's Avatar
buzzsaw
Has your cooling system been properly bled?
Old Sep 17, 2014 | 09:26 AM
Bombadier36
Everything has been dealership installed but I have not bled the cooling system myself.
I'll give it a try. From what I have read it seems simple.
Old Sep 17, 2014 | 11:12 AM
ZippyNH's Avatar
ZippyNH
"Warmer than you would like"= what?
Is the temp light on....fan running?
Aftermarket guage reading hi?
You list of mods seem very typical....should be well within the cooling ability of a stock cooling system if everything is running right.....
Since the cooling system on these cars is so often neglected....issues are common...
Often the failure is from improper bleeding...leaves the car OK for 5-10 minutes...then an overheat...
If the car has been serviced...I'd rebleed it....
But if it has been neglected....I'd flush the crap out if it....then refill, and bleed....
It not beyond the scope of possibilities a prior owner poured some stop leak in it while dirty...partially plugging the radiator and heater core, hopeing for a cheap fix....
Old Sep 17, 2014 | 11:23 AM
Bombadier36
It has been meticulously cared for, never neglected. I'll bleed it this weekend and see the results.
Old Sep 18, 2014 | 08:01 AM
nkfry's Avatar
nkfry
The temp gauge settles in right around half way, that's normal, what is the actual coolant temp? Read from a gauge, or scanner.
As stated, if the car isn't overheating or having the fans kick on constantly without the air being on you're within normal operating range. The car will give you a CEL for under temp, and you will get a dummy light and the gauge will bury itself in the event of overheating.
The cooling system should be flushed every 2 years, a pressure bleeder will make the process of making sure you've bled all the air out quicker/easier. Unless you are extremely low on coolant or had an improper system bleed done, the system should bleed itself, as the expansion tank is the highest part of the pressurized cooling system.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 18, 2014 | 08:58 AM
Bombadier36
Thanks for the thoughts. It sounds like I'm being more paranoid then anything
Kimolaoha
Jul 5, 2023 01:04 PM
Alkaidovich
Jan 30, 2021 01:35 AM
W0TM8
Dec 19, 2019 07:50 AM
David.R53
Sep 1, 2015 06:49 PM
Red Raven
Aug 11, 2015 04:48 AM
